SATURDAY, JULY 21 – 2019
*Mail in deadline – 16 July 2019*
*I have to photograph and make the web page for your car. We also have to have to test and tune along with the FAST LAP CHALLENGE. In the event there is only myself to test and qualify, this mail in date is important.
Please have it in by this date.
Only ONE car per class please.
INTRODUCTION |
4. – Entry Fee – $5.00. You can simply DONATE HERE for these. If you are sending from outside the continental USA, we will work with that as well.
List Of Events |
Our Track – Please click HERE for The Show-Me Speedway
Our track is a 5 x 16 foot, 4 lane, routed MDF. |
This does NOT sand them, just cleans them. The very mild 50% alcohol/water mix does not harm the tires or reduce the shelf life. It does NOT reduce diameter as already stated. I have tested this compound for nearly 2 years and all my cars from prior events are still in 100% performance.
Race Divisions
1. Sportsman – The standard full fender body styles. We are combining the older classics with modern late models. 2. StrangeBrew Modifieds – The famous modified series. Inspired by the modeling of our own “Strangebrew” Dave. |
APPROVED BODIES FOR SPORTSMAN CLASS – Carrera Classic NASCAR Ford Torino, Plymouth Road Runner, Dodge Charger. *** No Wing Cars *** – Carrera 57 Chevrolet, 60 Plymouth, 70 Chevelle, early release GTO, Mustang – Revell/Monogram Classic NASCAR – Galaxies, GTX, Charger, Fairlanes, Vintage 69 Nova kit – Scalextric -70 Camaro, 69 Camaro, 69/70 Mustangs, Challenger, Cougar, 69 Charger, 72 Torino – Pioneer Charger/Mustang/Camaro – SRP 55 Chevy, 56 Ford, 70 Chevelle, 69 Nova, 57 Nomad – SCX Cuda – MT Racing Resins – 70/71 USAC Racer, 69 Nova Sportsman, 65 Shovelle, Late Model 69 Chevelle. ASA Camaro, Mustang & Firebird – Gunze Sangyo – 57 Chevy hard top, 59 Chevy hardtop – Revell Snap-Tite – 55 Chevy, 69 Camaro, 70 Mustang, GTO, 78 Camaro, Firebird – RMS Resins Nova II, 65 Fury, 65 Galaxie, 66 Chevelle, 65 Impala, 63 Falcon, 67 Cougar, 68 Camaro, 68 Firebird, 70 Challenger, 70 Camaro, 70 Cuda, NEW CHEVELLE & DUSTER – Skunkworks ShapeShifter – Buick LM, 7123 Camaro, AM Camaro, 65 Ford, MA Cuda, New Bodies as available. * If you create your own resin bodies, please email me for approval. ***If you have an idea for a 3D body, please contact me.*** |
This is a special series that could include many different body styles. See the above photo for examples. If you truly want to enter a model in this division, please contact me with your body style idea. I will ask that your common sense should guide you first. Researching the classic modifieds will give you 1000’s of ideas.
Bodies must be as close to 1/32nd scale as possible. Body shapes should resemble the many prototypes easily researched.
American 2 door or 4 door sedans. Example: 40 Ford Sedan allowed. Cut down 57 Chevy Nomad allowed.
Interior: Must have driver, dash, steering wheel, roll cage detail.
Body Clearance To Track: 1/8″ is a good minimum
Body Height: Keep it stock. Original A/B pillars intact, in other words no low rider/rat rod chopped tops.
Body Width: Keep it stock. You can add flares if you want for scale appearance, but no narrowing of the stock body shell.
MAX Body Width: 2 5/8“. This applies to models with flaring. In other words, no wider than the allowed track width which is 2 5/8″
Body Style: American hardtops cars. No convertibles. No Trucks, Vans, SUV’s, Zamboni’s, Semi’s, Street Sweepers, etc. Common sense time.
Body Clearance To Track: 1/8″ is a good minimum. Front spoiler, if used, at 3/32nd. This will make sure the bodies/spoiler do not drag the track.
Must keep all fenders. This isn’t the modifieds.
Interior: Must have a driver, dash, steering wheel, roll cage detail. NO pre-molded lexan types.
Windows: Front needs glass or screen, your choice. Sides and rear optional.
Side Bars: Allowed but cannot be wider than the outer sidewall of tires. (2 5/8″)
Brass/Steel Wire Chassis. From scratch, but forged or stamped brass motor brackets and guide tongues are allowed.
Inline or sidewinder/anglewinder.
Offset motor configuration allowed.
No Slot.it pods or other plastic/3D/hybrid combos.
2 Wheel Drive Only. No 4 wheel drives. Must have 4 Wheels.
Chassis to Track Clearance: 1/8″ is a good minimum.
MAX Track Width: 2 5/8″ from sidewall to sidewall.
Stagger is allowed. In other words you can run a 15×8 on the left front and a larger size on the right front, just adhere to the width maximum.
Common sense rule – *If the chassis, gearing or body drag on the track? DQ. I will contact the builder and we will see if anything can be addressed to remedy it.
The goal is to create as close of a field as possible.
Click Below To See Wheels and Tire Combos
C.B. Design 15×8, 15×10, 15×11, 15×13
(Insert, Stock Car, 5 Spoke Racing, F1/MOD, & Classic Steel) If insert wheel used, please use an insert 🙂
The minimum size wheel/tire combination is 15×8 with PG 22125.
-22125, 22126 for 15×8
-22166FF, 22168FF for 15×10, 15×11, 15×13
REMINDER! MAX Track Width: 2 5/8″ from outer sidewall to outer sidewall.
Sidewinder/Anglewinder – Open
Motor
SPORTSMAN CLASS – Piranha Motor Only
Modifieds – Piranha – SCC JAWS Only
A complete video series on our chassis.
