by DRW21 » Wed Feb 10, 2016 12:55 pm
Try using a smaller pinion, this might sound crazy but drop a tooth or 2 and just try it, it will have a huge effect on the power curve of the motor and if you have short straights you won't really loose out on speed, your lap time may get quicker as you will have more brakes and can brakes later making the straights longer and you will have way more control over the way the car behaves. The motor will also run heaps cooler too.
Those Piranha motors are great!!!
