Thanks guys. Yes it was fun Rob. I plan to make more as it is very satisfying.
Blatz is still made. Pabst carries the label.
Using the resin leaves a very clean and smooth finish. Much like what a body looks like. I just feathered the edges a little with 600 grit. See the post on Fender Flaring.
THIS body is one that I made from the mold.
Wet sanded the entire body with 800 grit, primer coat, then wet sand with 1000. Painted the first base color then applied the top.
I used the fine screen mesh from a coffee filter for the front air inlet.
Mr. Brew, you name the time sir. I doubt my heap will keep pace with your effort. I might make a decent "ghost" car for you to practice your passing skills. Slotburgers on the menu for the next visit.
