GEARING HELP
Vintage to Modern
GEARING HELP
Postby bookie » Tue Nov 15, 2016 8:17 am
I rushing trying to finish my Drag Fun Run entry and I forgot about gearing. Need help selecting a good ratio for a 1/32 scale on a 55' wood track.
Thanks
bookie
Re: GEARING HELP
Postby fisherman » Tue Nov 15, 2016 11:53 am
55-feet, for more RPM try 10 pinon with a 60 tooth gear (533) ratio...But need to know your tire size...For more off the line you could try a 9/50
fisherman
Re: GEARING HELP
Postby TuscoTodd » Mon Nov 21, 2016 9:05 am
Rick -
With the power level of the motors we are using and the general short height of the 1/32 scale tires, you definitely want to trend toward the taller end of the spectrum in the way of gearing. Last year, the top contenders had gearing that hovered around the 2.5 to 1 ratio.
Hope that helps!
Return to Holeshot Alley!
Users browsing this forum: No registered users and 0 guests
