Home Racing World • View topic - Scalextric Legends by "Doc"
Page 2 of 2
Re: Scalextric Legends by "Doc"
PostPosted: Mon Oct 20, 2014 10:13 am
No trouble...we can just agree to disagree. :)
I wish it was different...but there are models made in slotcar form that are directed towards collectors primarily.
I still like them. Just VERY hard to take apart and tune for my purposes.
PostPosted: Mon Oct 20, 2014 12:54 pm
by dreinecke
PostPosted: Mon Oct 20, 2014 1:57 pm
by balsaworks
Right - I see what you mean, David. I have already pulled on that piece that you refer to but it's pretty firmly stuck.
It's getting late over here in the olde world, I'll check tomorrow with a sharp screwdriver if I can carefully pry it off without damage, it should be OK.
Thanks!
PostPosted: Mon Oct 20, 2014 7:00 pm
by dreinecke
Let me know how it goes!
PostPosted: Tue Oct 21, 2014 12:16 pm
by balsaworks
OK here's what happened: I used a fine screw driver and carefully removed the tail piece.
Unfortunately the locating peg was glued in place so it broke off and has remained in its slot.
No big deal, I drilled out both sides and attached a wire pin which works very well.
When I proceeded to untangle the maze of struts and tubes in the rear it turned out that other parts too are stuck really tight and look like they may also be glued. I decided to abandon the attempt and to remove the magnet from the outside rather than risk breaking more parts. The rim around the magnet was cut away by hand and then a dremel with a very fine burr was used to make one small hole just outside the edge of the magnet. The magnet is quite thin and once you get a tool around the edge at one point it pops out easily.
It's a good thing the car runs so well out of the box. I will stay with the too-powerful motor and run it on 9V.
It feels a bit strange not to be able to open it without risk of breaking it. I hope Scalextric will produce spare parts - that will probably be useful when I eventually have to take the car apart..
PostPosted: Tue Oct 21, 2014 9:58 pm
by dreinecke
Well...carp! I'd hoped yours would come apart easily. I'll be cracking open mine soon for their new motors. I'll let you know how it goes.
PostPosted: Wed Oct 22, 2014 10:58 am
by balsaworks
David, I have everything apart except for the flat rectangular pieces next to the wheel hubs that should come apart at the very last step. This piece separates easily on the one side but simply won't budge on the other side. I will wait until I absolutely have to, and then work on that piece with a sharp blade, and hope for the best.
Hope you have better luck!
PostPosted: Sat Oct 25, 2014 12:23 am
by miveson
The new Lotus 72C - fantastic looking model.
PostPosted: Sat Nov 22, 2014 5:34 pm
by VTECFOUR
Got my Gold Leaf and did a few changes.
1. Lowered the rear wing by slicing the posts at the base, drilling new holes and re-glueing.
2. Installed Fly March 761 F1 urethane tire re-pops as suggested and made by Luf. They've got a rounder profile. Fit and run just fine.
3. Applied Pattos Gold Leaf sponsor decals which really visually finished the car.
Thanks TF1250 for them.
PostPosted: Sun Nov 23, 2014 8:25 am
by dreinecke
Great work Dan! WOW did the wing work really change the profile of the tire!
I've got to get some of those decals...where did you get them?
PostPosted: Sun Nov 23, 2014 11:01 am
by VTECFOUR
Hi Dave,
Got the waterslide decals from a friend who kindly shared them from a whole sheet of Gold Leaf done by Pattos in Australia. This car seemed so bare without them. Scaley should have provided a little sheet for self application.
PostPosted: Sun Nov 23, 2014 11:02 pm
by dreinecke
Thanks for the info!
