Home Racing World • View topic - ninco kart guide repair
Postby seal666 » Mon Apr 13, 2015 8:34 pm
Need some help. The pin on the guide of 1of my ninco karts that controls the steering front wheels snapped. The loacal slot shop does not think th part is available. Anyone know where i can get one or how I can fix? Can you drill into the guide and make a post out of piano wire, or mabe tap it a use nylon 2/56 machine screw that Kadee sells for mounting couplers and trim th top off to fit?
Thanks
Bob e
seal666
Re: ninco kart guide repair
Postby waaytoomuchintothis » Mon Apr 13, 2015 9:44 pm
It should work fine. Do you have another one intact to copy? If not, I could take some pictures for you.
The only reason I think you could get into a bind is if the hardness of the machine screw doesn't yield enough under pressure to keep other, more pliable plastic parts protected from breakage.
Postby seal666 » Tue Apr 14, 2015 12:22 am
Yes i can copy my other unit. I appreciate the offer of the photos. Thanks for tne heads up on tbe need to have some flexibility and not transmit to much force into the other parts
seal666
Postby GTI » Tue Apr 14, 2015 9:21 am
Are you looking for guide flags for the Kart? If so I have some and I think you can purchase these as well in a package.
GTI
Postby nhdungeonracer » Tue Apr 14, 2015 10:22 am
Postby BRS Hobbies » Tue Apr 14, 2015 11:39 am
BRS Hobbies
