Home Racing World • View topic - Carrera guide replacement
Postby Jhobson » Mon Dec 11, 2017 8:03 pm
Does any one know of a better guide replacement for Carrera slotcar.
Jhobson
Re: Carrera guide replacement
Postby HomeRacingWorld » Mon Dec 11, 2017 8:08 pm
Postby Cincyslots » Tue Dec 12, 2017 10:20 am
You can also use these. They are a direct replacement except they fit better and are a tad deeper I believe. You can find them in some US shops. ;)
Bruce
Cincyslots
Postby buspor63 » Tue Dec 12, 2017 4:11 pm
buspor63
Postby HomeRacingWorld » Tue Dec 12, 2017 7:40 pm
Never heard of them.
The issue for most Carrera is the height of the entire guide system, not the depth or length of the blade.
They are mounted too high in the chassis and allow too much weight on the front. This makes the stock blade shallow in the slot, but just a deeper blade is not going to fix the issue.
Changing the system to unload the weight off the front tires and achieve a better tripod effect is where the performance gain is to me.
Postby Wobble » Tue Dec 12, 2017 9:44 pm
Wobble
Postby Cincyslots » Wed Dec 13, 2017 6:19 am
If you're only looking to lower the guide in the slot, trim the front tires to around 20mm OD and you're done. I would go much further than that. Carrera cars kind of heavy for the tripod IMO but do what works for you. There are a million ways to skin a cat. :D
Bruce
Cincyslots
Postby HomeRacingWorld » Wed Dec 13, 2017 6:26 am
On some that can work, but not all. You can also use offset bushings.
