32 Coupe with Ackerman Steering is done. Another one started
Re: Ackerman Steering? Or, are we insane?!?!
Postby Gameover » Mon Mar 09, 2015 1:55 pm
holy crap...... you have my attention!
Postby btaylor » Mon Mar 09, 2015 2:05 pm
Perfect! That will be stronger, more realistic, and just overall work better that RTR parts. AND its a renewable recourse! BRASS.
I am off work now, so I can try and catch up. Nice work Dave, the pictures don't show just how small those pieces are.You are so going to like the way this works!
Postby turbokev » Mon Mar 09, 2015 2:32 pm
:o
I thought I could hang with you guys.. no way I have the ability to make that small stuff free hand LOL..
Are you doing all that with a dremel? or do you have a drill press?
In any event, bravo.. that's awesome and I can't wait to see the end result.
turbokev
Postby TsgtRet » Mon Mar 09, 2015 2:45 pm
Totally awesome, Dave. That work is way above my pay grade!
As I posted on Bob's thread, I'm waiting to see which one of you comes up with a "roostertail dispenser" to add to the dirt track realism.
Postby waaytoomuchintothis » Mon Mar 09, 2015 2:52 pm
I've been fooling around with different ways of making Ackerman steering units for quite a while. I got the bug from Phil down under at Slot Car Outhouse. He makes them so small, he can get them under an English sports car in 1/32. Not only that, its actuated by the rear of the guide, so he can adjust toe-in, camber, and caster by simple bending of brass bits after its on the car. I was looking for a link last night but ran out of time. I'll look again.
Postby btaylor » Mon Mar 09, 2015 3:09 pm
I should feel guilty,, but I don't! This so cool to watch the cars go through the corners, that it worth every nail biting, screwdriver throwing minute of it! What are you using for the center hole in the drag link? I used the smallest tubing I had and cut a piece 3/32nd tall soldered to the link.
Postby HomeRacingWorld » Mon Mar 09, 2015 3:40 pm
I did not think I could get further behind...but I think I just got virtually lapped :)
Postby btaylor » Mon Mar 09, 2015 4:06 pm
Just so ya'll don't think I left Dave holding the bag on this, this little gem is about to go under my 36 modified chassis!
Postby btaylor » Mon Mar 09, 2015 4:39 pm
2mm brass rod for pins, then peen them from both sides. I soldered 1/8" tubing to ends to hold the pins. That's also what I used for the king pins. Same thing, peened on both ends. it holds them in, and you can tighten them up when they get a little sloppy from racing.
Postby Noahracing » Mon Mar 09, 2015 4:56 pm
This is so cool :banana-dance:
I know that Bob & Shotgun are going through the grunt work of designing this system, but, if I could make a suggestion, once perfected, maybe this is a piece perfect for 3D printing? ..........bibbster?
Great work guys... :text-bravo:
Noahracing
Postby waaytoomuchintothis » Mon Mar 09, 2015 5:07 pm
I think I remember that Phil used a washer, soldered top and bottom on the king pins, and again on the tie rods.
Postby dge467 » Mon Mar 09, 2015 5:53 pm
That is pretty neat! Doesn't Chase Cars make a 3D front end?
Postby dge467 » Mon Mar 09, 2015 6:04 pm
I agree! Keep up the nice work on the jalopies!
Postby Audi1 » Mon Mar 09, 2015 6:20 pm
WOW!
Postby chappy » Mon Mar 09, 2015 6:22 pm
Awestruck.
Nice work boys, really hard to work on stuff that small and your doing a remarkable job.
Bob C
