MRRC modified for Strombecker
Postby oz10k » Sun Jul 19, 2015 2:24 pm
I like vintage cars and I like to tinker. I've got a good number of old Strombecker cars and had been thinking for a while about chassis options. But every time I had an idea I ran into a roadblock, as I wanted to be able to use the existing body mounting posts.
Finally I ran across an old MRRC brass chassis that looked like it would work:
My first thought was to fit this inside a Strombecker chassis. So I took one and started cutting:
And it seemed pretty promising:
But I ran into two problems. First, I couldn't find a good way to connect the two chassis. Second, with a motor installed I had a clearance problem and I didn't want to hack the body to resolve it. So the project got tabled for a while.
Finally I decided to add some pans to the chassis for mounting. And having several bodies I found one that didn't have the clearance issue. In the front of the MRRC chassis I did have to expand the existing hole to a slot in order to get everything to line-up:
Now just a few minor details to wrap-up, then I need to work on the body:
Ron
oz10k
Re: MRRC modified for Strombecker
Postby TuscoTodd » Sun Jul 19, 2015 2:28 pm
Looks like a nice conversion!!!
:text-bravo:
Postby btaylor » Sun Jul 19, 2015 2:38 pm
Nice! One of my favorite pass times in this hobby, is getting old stromies up and running with more modern running gear.
Nice job!
Postby chappyman66 » Sun Jul 19, 2015 4:38 pm
I agree, the Strom bodies are pretty cool and with a little work can be made to look very nice.
I like the MMRC Clubman conversion. That's a decent chassis and with some pans you should have a nice running car. I have seen that plastic Strom chassis set with some brass tube for rear axle carrier/bushings, and those cars run pretty well too.
Nicely done.
Postby dreinecke » Sun Jul 19, 2015 7:01 pm
Very slick conversion. Sadly those Clubmans are getting harder to find.
