Home Racing World • View topic - Copper and brass headers
Postby woodman » Fri Jan 01, 2016 1:19 pm
I used 14 gage copper wire and 3/16 id brass tubing......Cut 4 3" lengths of wire and solder them into the tubing....I used my frame bending jig to make the first bend uniform, the rest are bent individualy
woodman
Re: Copper and brass headers
Postby acmost » Fri Jan 01, 2016 2:26 pm
Seriously, you guys are amazing.
acmost
Postby waaytoomuchintothis » Fri Jan 01, 2016 5:24 pm
I use solder for the manifold pipes, and brass tube for a collector, but it is pretty tricky to solder them into the collector, so I superglue them. I hate using superglue, so I'm tickled with this new method. I can't wait to get finished with all this crap I'm doing so I can build a stack of these guys. I've been stacking up bodies for nearly a year.
Postby TuscoTodd » Fri Jan 01, 2016 5:26 pm
That is a pretty slick trick!
Thanks for sharing!
Postby slowdogracer » Fri Jan 01, 2016 8:24 pm
What a great idea! That is awesome.
slowdogracer
Postby RV Racing » Sat Jan 02, 2016 10:05 am
Excellent! Thank you for passing this along.
Rick V.
RV Racing
