Home Racing World • View topic - Advice on Norrowing a Body
Postby Lotus56 » Mon Oct 30, 2017 1:16 pm
I need to narrow a hard body by about 3/8 inch. Other than cutting the center out of it what do you use to cut it with ie: dremmel, a saw? Then when putting it back together what kind of glue do you find works best and do you re enforce the seam with as strip of plastic.
Lotus56
Re: Advice on Norrowing a Body
Postby munter » Mon Oct 30, 2017 6:37 pm
I havent done this but think I would start with an Exacto razor saw...using the deepest blade available.
You should then get a clean straight cut.
You say hard body...is that plastic or resin?
Postby Lotus56 » Mon Oct 30, 2017 11:38 pm
Plastic
Lotus56
Postby munter » Tue Oct 31, 2017 12:52 am
If you have a straight clean cut you can then remove material from the edges using a sheet of sandpaper glued to a flat surface and rubbing the edges of the cut on it.
Gluing?...I like superglue but for plastic there may be something better. Only use epoxy/Araldite as a strengthener on the inside not as an actual adhesive to rejoin the body parts.
I sometimes use hotdog sticks cut and shaped as strengthening on the insides of resin bodies, runny superglue loves those and you can construct internal struts etc easily.
Good luck.
Why are you narrowing the body and what is it?
Postby RichD » Tue Oct 31, 2017 9:33 am
I use the same method. It would be nice to have one of these.
Postby Lotus56 » Tue Oct 31, 2017 11:24 pm
Thanks everyone, going to it a try...
Munter
""Why are you narrowing the body and what is it?""
because it won't look right and what it is, its a XXXX????? and I am going to use for the XXX???%$$....Secret
Lotus56
Postby munter » Wed Nov 01, 2017 3:09 am
