Home Racing World • View topic - Hard tires
Hard tires
Hard tires
Postby frank9129 » Mon Mar 31, 2014 4:18 pm
I am having a hard time, no pun intended. Allot of my Artin tires are giving up the ghost and getting hard and oily.
I think I have come onto why my rear tires are getting hard, and not the front. :violence-stickwhack:
The rear tires are spinning on the track and the front only roll. The rear tires heat up as they push the car around the track. Repeated Heating and then cooling results in them hardening.
It sounds good to me. I have been switching the fronts to the rear as they get hard.
Now, I have everything I need to start making my own tires.
Does anyone have any suggestions before I start making molds on Saturday?
frank9129
Re: Hard tires
Postby a110alpine » Tue Apr 01, 2014 2:41 am
put some orange goop hand cleaner on them .
a110alpine
Re: Hard tires
Postby frank9129 » Tue Apr 01, 2014 6:02 am
Gina try it.
frank9129
Re: Hard tires
Postby munter » Tue Apr 01, 2014 11:38 am
What hardness urethane will you use?.....20 or 30shore for the rear would be good and 40shore for fronts
Re: Hard tires
Postby frank9129 » Tue Apr 01, 2014 2:39 pm
Vytaflex 40 Urethane Rubber Compound from Smooth On.
frank9129
Re: Hard tires
Postby frank9129 » Thu Apr 03, 2014 8:39 pm
The first dozen molds are in the cups. I am starting with Nascar Artin tires. A dozen should get me started.
I will make some others next week if these come out as usable. I do understand that the first casting tires are a bit sticky, but later castings come out fine.
Wish me luck.
frank9129
Re: Hard tires
Postby frank9129 » Fri Apr 04, 2014 8:27 pm
The first dozen tires are out of the molds. Then it hit me. Figuring the amount of material needed for the molds was easy. Put the tire in the cup, fill with water until the tire is covered by 1/4 inch. Multiply by the number of tires being cast. No big deal. Now, how to calculate the amount of material necessary to make the tires. That is something different.
Any help?
frank9129
Re: Hard tires
Postby frank9129 » Sun Apr 13, 2014 6:44 pm
The first Artin Stocker tires are on the cars. They hook up like nothing I have tried yet.
There is another batch cooking. I learned a few things with the first batch. No disaster...But the day have a few hours left.
frank9129
Re: Hard tires
Postby ElSecundo » Mon Apr 14, 2014 12:29 pm
ElSecundo
The Great One
Re: Hard tires
Postby noddaz » Mon Apr 14, 2014 6:54 pm
Tires Frank!!?? Look at you go! Good job on the tires...
Scott
noddaz
Re: Hard tires
Postby frank9129 » Mon Apr 14, 2014 7:25 pm
El,
Thanks, I used that to make the molds. There will be another style of tire to mold this weekend.
frank9129
