SLOT IT SISP21 PINION GEAR PULLER & PRESS SOLD Delete
Used Car Salesman?
Buyers & Sellers HQ
Forum rules
Postby carlosinseattle » Wed Mar 07, 2018 11:21 am
SLOT IT SISP21 PINION GEAR PULLER & PRESS FOR SLOT CAR MOTOR AND GEARS NEW FOR 1/32 & 1/24 SLOT CARS
BRAND NEW IN PACKAGE.
I bought it after using a friend's at the track. But realized the press isn't going to work for the type of motors I use most often. The press is new in the package.
$60.00 plus shipping with Paypal as a gift. If paying for goods and services you pay $65.00 plus shipping. It's on the auction site but would prefer to sell hereon HRW.
Last edited by carlosinseattle on Fri Mar 09, 2018 1:02 pm, edited 1 time in total.
carlosinseattle
Re: SLOT IT SISP21 PINION GEAR PULLER & PRESS NEW $60
Postby FC47 » Thu Mar 08, 2018 5:42 am
Carlos,
I've got one of these and use it on my 24, and 32 cars,
Curious tho, which motors do you find you can't work with?
FC47
Postby carlosinseattle » Thu Mar 08, 2018 9:39 am
Thanks for asking. It really is a GREAT puller! I love the build quality and how everything fits together so precisely. I mainly need a press for my RMS-124 motors for Carrera D124 cars. There's a short shaft on the non drive end of the motor and the problem with this puller is that it pushes on the plastic endbell which can shove the comm offline with the brushes. I need one that pushes the pinion on one end and the shaft, really short shaft, on the other end. The RMS motors also have a splined shaft for the motor, which means I have to use a lot of force to get the pinion on. I realize that's not an issue with the vast majority of motors. So it's not a short coming on the part of the press, just a unique situation for me. It works great for BRM Scaleauto and all other cars/motors.
carlosinseattle
Postby FC47 » Thu Mar 08, 2018 9:48 am
I gotcha. Bummer, just looked at mine and a motor like your talking about.
Man if the cupped insert was shallower, and the hole less deep you'd be all set, we all would,
Just a plain turned insert with a center dimple would do it.
What pinions have you put on those motors/cars that you liked?
FC47
Postby FC47 » Thu Mar 08, 2018 9:58 am
I bet you could put a dimple on the other end of the cupped insert?
FC47
Postby RazorJon » Thu Mar 08, 2018 10:21 am
I could modify it for you, send me a email with your phone number and we can talk
scrjon160@aol.com
Postby HomeRacingWorld » Thu Mar 08, 2018 11:53 am
Just a FYI or perhaps not much help at all...but...
If there is this much pressure try this: Run the motor under power (use a 9 volt battery) and use some 800 or 1000 grit sandpaper by hand on the end. Sand the spline smooth (or close) and that will reduce the pressure. It will also help prevent distortion of the pinion and possible cracking, yet still allow enough pressure for a secure pinion.
Postby carlosinseattle » Thu Mar 08, 2018 1:07 pm
Thanks Harry!
Thanks Jon!
I really appreciate the offers for help.
This Slot.it is a really nice press and puller and I thought guys would jump at the chance to get it at a great price. And I also ordered a Frenkenslot puller and press already; didn't want to have to modify this one since other than my issue it is a fantastic tool. If for some reason the order doesn't arrive I'll explore the other options.
carlosinseattle
Postby carlosinseattle » Fri Mar 09, 2018 1:02 pm
Sold on the auction site.
carlosinseattle
Return to FOR SALE!
