Scalextric NASCAR tires
Postby torquemutant » Tue Sep 24, 2013 6:43 am
Super Tires #1101 for use on Scalextric NASCAR has a 2mm rib and an outside diameter of 20.37mm. Can I get this same tire in a larger outer diameter and still have the 2mm rib? Width is of no concern. :?:
torquemutant
Re: Scalextric NASCAR tires
Postby SlotCarCorner » Wed Sep 25, 2013 4:31 am
Unfortunately there is not a Super Tire that fits the stock Scaley Nascar wheel with a larger o.d. (the 1103 will fit but hangs over both sides of the wheel slightly and has a smaller o.d.). If you are not restricted to using the stock wheel, an alternative might be to use a C.B. Design Stock Car Wheel - this would give you a much wider range of Super Tires to choose from.
SlotCarCorner
Postby RazorJon » Wed Sep 25, 2013 6:49 am
Paul Gage Tires makes them, and they work great for me
Postby torquemutant » Thu Sep 26, 2013 12:03 pm
We are restricted to the stock wheels. PG tires also are a good choice but I was hoping for a little taller tire. Thanks guys.
torquemutant
Postby paul gage » Thu Sep 26, 2013 1:46 pm
PGT-21102 is the stock size, and PGT-22122 for some fatty's... SCC has the PGT-22122 listed in both compounds :)
paul gage
Users browsing this forum: No registered users and 39 guests
