Mini Cooper S - Finished! - video on Big Targa added
Postby VTECFOUR » Mon Mar 07, 2016 5:23 pm
Got a soft spot for the classic Mini so I'm moving forward using the nice Tamiya Mini Cooper S kit as the basis.
With the results of my first sidewinder motor pod chassis for a friend's build, I can see that it'll easily fit within the model's dimensions.
It'll need a shorter front assembly with the guide post right to the axle tube so the guide is tucked in.
Although the kit's a 1/24th version, I'll be running it with the 1/32 cars in our club's Open class. It's smaller than some of the cars being run so I don't think anyone will object.
I'm excited by this build as it'll remind me of my 1:1 car sold off a few years ago.
Stay tuned.
VTECFOUR
Re: Mini Cooper S
Postby TuscoTodd » Mon Mar 07, 2016 5:35 pm
Should make for a sweet looking runner when you are done! :D
Re: Mini Cooper S
Postby Retro Racer 44 » Mon Mar 07, 2016 6:28 pm
Well Dan, I don't know. A 1/24th running against our 1/32s. unthinkable. Besides, your 1/32 Minis can kick my a$$ so this should be unbeatable. :lol: :lol: :lol:
Looks like a great build. go for it, eh?
Keith
Retro Racer 44
Re: Mini Cooper S
Postby VTECFOUR » Fri Mar 11, 2016 3:01 pm
Didn't work out to use a Slot It sidewinder motor pod and my wheels/tires, so I'm going with my tried and true chassis using the Devised Designs super slim FF050 motor pod.
Brass square, round and strips cut and ready for soldering.
Should be assembled and running in a couple of days.
VTECFOUR
Re: Mini Cooper S
Postby VTECFOUR » Mon Mar 14, 2016 3:42 pm
Chassis's assembled and rolling.
Going for this low down stance so the side pans are as close to flush with the body's sills.
Rear wheels\tires aren't scale but I'm going for performance.
VTECFOUR
Re: Mini Cooper S
Postby VTECFOUR » Tue Mar 15, 2016 7:25 pm
Chassis's running. Goes well as it's a tried and true formula for many of my builds.
Cosmetically, sawed, filed and sanded the kit's S steel wheels into inserts for the 14.3 front and rear rims.
Mounting the body is next.
VTECFOUR
Re: Mini Cooper S
Postby dreinecke » Tue Mar 15, 2016 8:15 pm
Super build Dan!
Re: Mini Cooper S
Postby TuscoTodd » Tue Mar 15, 2016 8:42 pm
That is one CLEAN looking build sir!
Two thumbs up!
Re: Mini Cooper S
Postby VTECFOUR » Wed Mar 16, 2016 3:38 pm
Body's mounted.
Went for the chassis side pans to be flush with the body's sill, so it's quite slammed at the back. Front could be lowered just a bit.
Did mounting posts at the front and back so I could use more of the kit's interior pieces. Fortunately, the front post lined up just under the scuttle panel allowing a removable bonnet to reveal engine bay detail.
Chassis and tires have lots of clearance from body so no performance-robbing rubbing.
Working out well so far. On to some modelling work.
VTECFOUR
Re: Mini Cooper S
Postby VTECFOUR » Sat Mar 19, 2016 8:51 pm
Mock fit the kit's wheels modified into wheel inserts and the chrome hubcaps.
The stock look with the slammed rear works for me.
Had the opportunity to test run on Luf's Targa Burnaby and got down to a respectable 7.89 fastest lap. Met my objective to be able to run with a Slot It car.
Much more modeling to go.
VTECFOUR
Re: Mini Cooper S
Postby VTECFOUR » Thu Mar 24, 2016 12:20 am
Roof and bonnet test fitted.
Really looking like a Mini now.
Slow going on the fiddly stuff including the engine bay and motor fitment and fabricating a flat interior tray incorporating the kit's dash and partial seat detail.
Being patient.
VTECFOUR
Re: Mini Cooper S
Postby VTECFOUR » Thu Mar 31, 2016 6:09 pm
Want to include the kit's engine detail, so lots of fiddling to install and allow free rotation of the guide.
Getting there.
VTECFOUR
Re: Mini Cooper S
Postby VTECFOUR » Mon Apr 04, 2016 11:27 am
A little progress with some engine detailing.
Mixed some Tamiya bottle green and black to get the desired darker green. Kit's carb air filters were replaced with guide eyelets for a simulated trumpet look.
Slow going, but not rushing this build.
VTECFOUR
Re: Mini Cooper S
Postby Beast Lee » Mon Apr 04, 2016 11:55 am
That's looking awesome Dan...!!!
Beast Lee
Re: Mini Cooper S
Postby Lou E » Mon Apr 04, 2016 12:29 pm
That is so cool! How do you plan on keeping the hood closed?
Lou E
