Home Racing World • View topic - Ford - Ferrari Wars Proxy - Rules & Roster
Re: Ford - Ferrari Wars Proxy - Rules & Roster
Postby Audi1 » Fri Feb 12, 2016 5:42 am
Tony, I'll make the change to the 312 PB - good car sets up a lot like the Slot.It Alfa T33/3.
Arroldn, let me know as soon as you've made your in/out decision; thanks. Yes, there are a lot of proxies going on this Spring!
Eightwheels, thanks for the update. Plan to ship mid-March, if that works for you.
How about the rest of you........................?
Postby redlynr » Fri Feb 12, 2016 7:26 am
Still in... Car done, just need to tweak a bit and switch to non silicone rears.
redlynr
Postby nhdungeonracer » Fri Feb 12, 2016 9:13 am
Postby Audi1 » Fri Feb 12, 2016 9:22 am
Thanks for the update, Steve.
Dickie, you're in with your 512 Furrie! Should be fun!
Postby Audi1 » Fri Feb 12, 2016 7:55 pm
OK, so far I've hear from 5 out of 35 entrants. What about the rest of you...........................? Let me know what's up with your cars; thanks.
Postby chrisguyw » Fri Feb 12, 2016 10:51 pm
Hello Allan, My entry is ready to go......will be there before the deadline.
Chris Walker
chrisguyw
Postby DRW21 » Fri Feb 12, 2016 11:53 pm
Still trying to get my P68 to work 1/2 decent.
Should make it in time.
DRW21
Postby OrakeiRacer » Sat Feb 13, 2016 3:34 am
Hi Allan, I'm still in - working on a Ford P68 #33, hopefully send with DRW21.
OrakeiRacer
Postby Audi1 » Sat Feb 13, 2016 11:21 am
Thanks Chris, Dave and OrakeiRacer (is that jmac?); all sounds good!
That's 8, how about the other 27 of you.....................?? Let me know; thanks.
Postby chappy » Sat Feb 13, 2016 11:29 am
I'll be there by March 31st, just having a little engine tune up by Ernesto of my non existent
sponsor's.
Postby Aloha » Sat Feb 13, 2016 11:36 am
I have two staying warm before they take the track to cold northern tundra. See you soon.
Aloha
Dale
Aloha
Postby McLiams » Sat Feb 13, 2016 3:17 pm
It is sitting on the bench. Have never entered a Slot It before. Still sort of scratching my head about what needs to be done beyond glue and true tires.
Mc
McLiams
Postby Audi1 » Sat Feb 13, 2016 3:53 pm
OK, that's 3 more, so we only have 24 left to hear from.................
Bill, you might want to check that the chassis is straight, if not, then heat-straighten it, glue the spherical rear axle bushings in place with CA glue, check for float on the pod, put grub screws in the top and bottom front axle carriers, change the braid, see if a Piranha motor might be a better option than the S can that came with the car (if not an AW Flat 6 set-up), have a look at the gearing, consider a cut-down wood guide, perhaps a lexan interior tray...............and a bunch of other little things................. :lol:
Postby mikeinclover » Sat Feb 13, 2016 4:38 pm
Count me out Allen.
mikeinclover
Postby urbanwarrior » Sat Feb 13, 2016 4:56 pm
As per my PM I'm in. I also posted my cars in the build thread recently.
John
urbanwarrior
Return to Ford-Ferrari Wars Proxy
