If anyone is interested, I've decided to make my meat tray softbox a little more efficient. A meat tray softbox is a must have :dance: ...ok, that might be a stretch! Anyway, here is what you will need:
1. A meat tray
2. Packing tape (clear is better)
3. Styrofoam packing sheets
You'll also need an Xacto, or some kind of sharp blade to cut out the bottom of the meat tray...
Once you cut the bottom out of the meat tray, save it...it's a handy reflector!
Cut out a sheet of the styrofoam packing material the size of the opening you just cut in the meat tray.
Tape that piece about half way in the depth of the meat tray...this is called the baffle.
Now cut a piece of the styrofoam material the same size as the big opening of the meat tray.
Tape that over the opening, and you have a meat tray softbox!
All you have to do now is tape it to the light source, and start shooting!
