Monogram Vintage NASCAR
Postby Kemtronracer » Wed Sep 12, 2012 1:31 pm
What is the purpose for the resistors attached to the motor in a Monogram Vintage NASCAR? Can they be removed if you're running at 10 volts?
Kemtronracer
Re: Monogram Vintage NASCAR
Postby HomeRacingWorld » Wed Sep 12, 2012 1:36 pm
You can safely remove them.
Some of that is for RF noise reduction which is required by law.
Postby Burglar » Thu Sep 13, 2012 12:02 am
None of my cars have these resistors. I must be very naughty. For simplicity's sake I just have two lengths of plain wire (one red, one black) on each of my cars
Burglar
Postby Florida_Slotter » Thu Sep 13, 2012 12:19 am
Heck, I'm sure no one here has ever done ANYTHING to add to the 'hash' that bothers our electronic devices!
Hey, adding solid core ignition wires made the cars run better. You just could not hear the AM radio any more!
Postby FootScoot » Thu Sep 13, 2012 5:38 am
That usually one of the first things I do, remove all those doo dads from the motor, and install Professor Motor wires. I've heard of cars that quit running because those little thingies go bad. :)
Postby DAVE » Thu Sep 13, 2012 3:50 pm
Those are condensers, not resistors. They are there to cut the RF noise. They
are not needed for racing, and may slow the car an unnoticeable bit. They will pop
with a voltage spike and cut the circuit so the motor won't run. I cut them off the
first time I open the car.
DAVE
Postby waaytoomuchintothis » Thu Sep 13, 2012 6:02 pm
And it should be said that they are required by law in Europe, not here. Our RF noise stuff is mostly about actual radios, like CB, Marine, Aero, etc. We don't use 240v for household current, but Europe, for the most part, does, with different phases and all kinds of things different from us. Even electric can openers in Europe have those little condensers on the lead wires.
