Stumped (Again) Ninco
Re: Stumped (Again) Ninco
Postby Ember » Wed Apr 23, 2014 7:20 pm
That makes it the same configuration as the Ninco1 motors, doesn't it?
Have you tried the B-Nova motor adapter at all? I have several pod the Ninco ones, but I'm sure someone closer to you must have them.
Postby Dangermouse » Thu Apr 24, 2014 2:37 am
Yep all my NC-8s are FK motors a shorter NC-5 motor
so yes it looks more like the new Ninco 1 motor
like this one Image
Dangermouse
Postby BRS Hobbies » Thu Apr 24, 2014 8:11 am
All the NC-8 motors that I have seen look like the picture mfogg posted and the one pictured above by Dangermouse. The NC-8 motor that Ember posted is a graphic put out by NINCO but I have never seen an NC-8 motor look like that with the rounded end bell.
Basically, if you can get a motor pod or have a chassis that accepts an NC-5 long can motor, than the NC-8 motor will work using the included adapters. Also, an NC-1 short can motor can be installed in a long can motor mount using the Ninco 80608 motor adapters.
I don't know of any adapter to install an NC-8 motor in a NC-1 short can motor mount.
Hopefully this will clear up the confusion.
Best regards,
Brian
BRS Hobbies
Postby Dodgefarmer » Thu Apr 24, 2014 4:20 pm
Thanks again Brian, I think I have it figured out now. Theoretically if I could locate a 70127 bracket and a new NC8 with adapters I could make this work. But in reality I have been unable to locate said bracket (even on ebay) and the NC8>NC5 adapters are not sold separately so it's not a feasible swap.
Randy
Dodgefarmer
Postby mfogg » Fri Apr 25, 2014 8:14 am
mfogg
Postby Ember » Fri Apr 25, 2014 4:31 pm
My fault. Sorry about that. I'd swear I have an NC8 just like that, but I probably have it mucking fuddled.
You can fling your tomatoes this way.
Postby mfogg » Fri Apr 25, 2014 4:52 pm
mfogg
