What after market tires do you recommend?
Postby Joe A » Tue Nov 06, 2012 8:47 pm
My plastic track is Carrera and my cars are all stock, various brands. I need to start thinking about getting tires, what do you recommend?
Thanks
Joe
Joe A
Re: What after market tires do you recommend?
Postby HomeRacingWorld » Tue Nov 06, 2012 9:28 pm
Paul Gage. He makes a lot of tires that are great on that surface.
SlotCarCorner makes Yellow Dogs that I like as well. I use the new rounded sidewalls on my Slot.it's.
Postby RazorJon » Tue Nov 06, 2012 11:47 pm
On my dirty Carrera track Paul Gage are the best
Postby Modlerbob » Wed Nov 07, 2012 1:14 am
From my point of view you have been given very good advice. I have Scaley Sport plastic track and we use either supertires or Paul Gage tires, depending on the car.
Postby FootScoot » Wed Nov 07, 2012 6:37 am
Yep, Super Tires Yellow Dogs, or Paul Gage. :)
Postby Cincyslots » Wed Nov 07, 2012 7:49 am
We run non-mag on Carrera. Supertires are the tires we prefer.
Bruce
Cincyslots
Postby Cincyslots » Wed Nov 07, 2012 9:12 am
test
Cincyslots
Postby raceeng18 » Wed Nov 07, 2012 9:31 am
NSR rubber worked well when I was running on plastic. Since then I've used the same and Paul Gage.
Joe F.
raceeng18
Postby OctagonSpirit » Wed Nov 07, 2012 10:10 am
I have to agree on Supertires from Slot Car Corner, though I do have a place in my heart for Indy Grips. Both not only have good grip, but good fit on a variety of wheels as well.
However, if you venture to wood, do yourself a favor and get a set of ScaleAuto foam tires. Experiment with different compounds (they have three levels of softness) but you will be astonished with how good your car can be.
OctagonSpirit
Postby DaveKennedy » Thu Nov 08, 2012 8:53 am
SuperTires silicone tires.
Postby sirslotsalot » Thu Nov 08, 2012 10:14 am
Just curious. Is there a major advantage using silicone instead of urethane or just preference. I run plastic track and have good luck with urethane as they seem not to collect so much dust.
sirslotsalot
Postby nhdungeonracer » Thu Nov 08, 2012 2:45 pm
sirslotalot, it does come down to preferance, but silicones generally work better if the track is cleaned regularly. If the track isn't cleaned on a regular basis, then urethanes generally work better, because as you mention, they don't collect and hold onto the dust.
Postby ecr » Thu Nov 08, 2012 7:19 pm
We use the tires from KD tires and found a large difference on plastic and on wood,
if he hasn't got the ones u want just sent in what u need and he will make a pair .(MAKE ARRANGEMENTS)
Kevin was always helpfull for us. Now that I mention it, I should get another order together shortly !
He can be found in Helpful Quick Links off the main page :animals-dogrun:
ecr
