I used an old plastic pilot figure as my driver. Had to do some surgery to get him to fit into his new race truck cockpit.
The front grille was opened up to improve air flow by sanding plastic off the back - works great.
The 1/24 AMT slot kit provided a wide track chassis that made wheel flares necessary. Lots of putty and sanding required to make them look decent - here it's in process.
Partially finished interior set on chassis.
Rough pickup body set on chassis for test fit.
First coat of primer is on, still need lots of sanding, polishing and finishing.
Driver does fit into the interior.
Still need a seat belt to keep the driver safe.
Paint is now on body, bed cover and front splitter.
AMT chassis ready to put under the truck. The front tires are from an AMT 1/25 plastic kit (Dodge Caravan, I believe), sanded down to a lesser diameter.
Chassis mounted under the pickup body. A couple of button magnets were added to help with road holding in the corners.
Decals and stickers were applied and soon we'll be ready to race.
Some of the decals were a bit old and look rough around the edges. Oh well, they'll get really banged up once we start racing anyway.
Almost ready to go - seat belts on, window net up, time to fire her up.
Finally, we're on track and rumbling past the pits at Overlook Raceway Park.
Hope the photo of our new race truck turns out okay.
Our truck looks okay and the fans seem to think so too but handling is still pretty shaky - need some serious tuning to get lap times down into respectable territory. I'm not sure that this AMT metal chassis is really all that good but we'll give it a try. Here's a link to the truck on track at Overlook: viewtopic.php?f=32&t=14917&p=188192#p188192
