Home Racing World • View topic - Ford vs Porsche Proxy Round 10 - PMCC
Here we go! Round #2 in what started last year as a proxy duel between both builders and marques.
Postby gascarnut » Thu Jun 21, 2018 10:52 am
Round 10 of the 2017/8 Ford vs Porsche Proxy is planned for June 30 at the Pebblestone Model Car Circuit (PMCC) in sunny SoCal.
The cars arrived safely from New Zealand on Saturday, and although I have not yet unpacked them all, they appear to be undamaged by the long trip.
PMCC is a three-lane routed track that stands on the patio behind my garage. It has been used for a great number of Proxy races in it nearly 10-year life so far.
Power is from a Pyramid PS26KX that is normally set to 12Volts, racers can use either their own controllers or the provided Professor Motor diode controllers. We will run two-minute heats and rotate each car through the lanes twice, to get 12 minutes of racing per car. The two rotations through the lanes will be done with two groups of drivers, so each car will get 6 drivers.
Unlike previous events, there will not be any live streaming this time, but I will try to have some almost real-time updates as we proceed.
More later as we get closer to the date.
Dennis
gascarnut
Re: Ford vs Porsche Proxy Round 10 - PMCC
Postby Audi1 » Thu Jun 21, 2018 1:14 pm
Thanks for the update, Dennis. Good to know that the cars made it safely and quickly from New Zealand.
Thanks also for scheduling the race so quickly; that helps a lot as we now head into the last 3 Rounds; 10, 11 and 12.
Best,
Postby CrockettNZ » Thu Jun 21, 2018 11:46 pm
nice track
looking forward to the race and good luck everyone
CrockettNZ
Postby Smokeio » Fri Jun 22, 2018 4:19 am
Oh no. Not Dennis.
Smokeio
Postby kidvoltage » Fri Jun 22, 2018 7:27 am
Go team Porsche. Let's take those Fords to task!
kidvoltage
Postby gascarnut » Fri Jun 22, 2018 10:52 am
gascarnut
Postby Audi1 » Fri Jun 22, 2018 5:48 pm
The #23b at PMCC - could be a hard car to beat...…………
Good luck to all!
Postby Brumos RSR » Fri Jun 22, 2018 7:44 pm
Brumos RSR
Postby gascarnut » Sun Jun 24, 2018 9:58 pm
I managed to do qualifying today for the event on Saturday. Results will go up in the morning once Ihave massaged the Trackmate Excel file and added a few tenths to Smokeio's time...
Good news for Porsche fans, though. As some of you expected, the #23g from Kidvoltage topped the charts, with the #63 long-tail 917 in second. The #21 rounds out the qualifying podium.
The top 11 cars all ran under 6 seconds, which on my track is a quick time.
More tomorrow.
Dennis
gascarnut
Postby gascarnut » Mon Jun 25, 2018 11:30 am
Right, here are the full results from yesterday's qualifying runs. I ran each car for a few laps to get my controller set up, then ran a 1-minute heat. When I de-slotted, I stopped the timer to re-slot the car and then continued.
This Proxy has a fairly large spread of times from top to bottom, a bit more than I have been seeing in previous series visiting PMCC.
A few general comments so far:
1. There is a wide variety of chassis designs, from full-blown scratchbuilt cars of brass and wire to home-made lexan sheets, to "Strapping tape Specials" to almost stock non-podded frames.
2. Quite a few cars suffer from having guides that are way too shallow in the slot, and often the same cars have a lot of play on the guide mounting. This does not bode well for racing.
3. Some cars are losing their brakes. Perhaps they did not have too much to start with, but this will also be detrimental to good lap totals.
4. A lot of cars suffer from some form of chatter. In some cases this is a matter of play in bushings, in some cases the taping of the chassis is either insufficient or in the wrong place.
5. Some tires are showing signs of the long series, bodies have been rubbing and re-profiling the sidewalls. Some tires now have sharp edges, perhaps due to wear, perhaps they were not rounded off to start with. Either way, this causes chatter and unpredictable slide on my track.
6. On my track, rubber tires have an advantage over urethanes, although some well-prepared urethanes can be competitive. Air system wheels also help here.
No cars suffered any damage in the trip from NZ, and all cars ran fine during their qualifying, apart from one where the motor popped out and had to be re-glued into its pod.
Racing will be Saturday June 30, starting around 1:30pm PDT. There will not be any streaming, but I will try to update the results in as close to real time as I can.
Dennis
gascarnut
Postby OrakeiRacer » Tue Jun 26, 2018 9:47 pm
Nice one Dennis! Your track looks very similar in parts to our home track. Looks like Porsche is trying to make a come back. Looking forward to the race.
OrakeiRacer
Postby CrockettNZ » Wed Jun 27, 2018 1:20 am
thanks for the qualifying and I am looking forward to the race
I have 2 proxy's to watch this weekend
CrockettNZ
Postby Brumos RSR » Wed Jun 27, 2018 6:43 am
Thanks for the qualifiying run Dennis. Way to get out front Kidvoltage and SS1963 the Porsche team is proud. Also DRW nice qualifying run as well, if the builder of the #33 Porsche Would have made the driving figure .005grams lighter......hmm. Good Luck to all on Saturday
Brumos RSR
Postby gascarnut » Sat Jun 30, 2018 12:52 pm
Race day is here, bright and sunny and not too hot, with a nice breeze blowing through the patio where the track stands.
Preparations are complete, now we wait for the drivers to arrive, a bit of practice with other cars, then serious racing for the afternoon.
I willl check back and update as we go.
Dennis
gascarnut
Postby Audi1 » Sat Jun 30, 2018 7:14 pm
We're ready!
Good luck to everyone! :auto-layrubber:
Return to Ford-Porsche Wars Proxy 2017
