by Alan132 » Sun Nov 24, 2013 8:58 am
Ok everyone. Going to change directions here. I was up to 2 am this morning running all sorts of tests and although I would really like to use the custom HO track for the 1/43 racing it is not that good. Electrical pickup is the major issue. Having the braid adjusted to match the HO rails is not hard to do but where it suffers is very little down force of the braid to the thin rail. For those in the know on HO cars their pickup system has springs etc that apply a good down force to the rail and they turn very good times.
If the rails on my HO track were wider there would be much more surface contact and therefore more current flow. I looked at all this last night with some very expensive test equipment.
The conclusion :
#1 I will move my HO track to another area as I will not be using it that much now.
#2 I will install 1/32 Scaley Sport Track down for the 1/43 track.
#3 Big thing to the racers should be no modification to their cars - that makes thinks simpler!
SO the work starts today - I will post pictures as the work moves on!
SO forget about having to mod your cars !!!!!!!!!
Alan
