what´s on your bench right now? [1/43]
Postby pfuetze » Sun Sep 10, 2017 9:02 am
started the chassis for the Buggyra Truck.
should start in the 3-race proxy in october - time to get going!
Postby BARC 1 » Sun Sep 10, 2017 10:09 am
Can you give more info on the truck proxy. Lloyd mentioned it to me, but I haven't heard or seen much about it
Postby pfuetze » Thu Sep 14, 2017 12:37 am
info on the truck proxy in a seperate post, Dan!
more work on the truck chassis, now waiting for the wheels to arrive from shapeways!
and drilling of H0 crown gears to make them fit on 2.38mm axles. 3 good ones, 7 to be questionend and 7 will go directly to the bin.
tried several thing to get a right angle and centered, but got all kind of wrongs: not right angle, off-center, both and also 1 too large hole when experimenting with the speed of the drill.
back to the drawing board!
Postby Dodgefarmer » Thu Sep 14, 2017 12:59 am
Peter, try using a 2mm axle to align the bore in the gear with the drill press chuck. Then dull (flatten or negative rake) the cutting face of the drill so it won't "grab" the existing bore in the gear.
Randy
Dodgefarmer
Postby pfuetze » Thu Sep 14, 2017 1:56 am
Randy, thanks for the idea!
the existing bore in the crowns is 1.5mm
i could use a piece of axle to align the crown, clamp it fixed, switch to the 2.2mm drill bit and drill the hole.
most of the crowns are off-center but nicely right angled, so my problem really seems to be the centering. With the 1.5mm axle, this problem should be gone.
Will try it in the evening and report, i got 3 crowns left to try :)
Postby pfuetze » Sat Sep 16, 2017 7:06 am
started the works on a Mini Pickup, want to run it in the truck proxy series. will have the new ball bearing chassis, i like how it runs in the other mini.
waiting for the wheels to arrive from shapeways for the Buggyra truck.
Postby pfuetze » Mon Sep 18, 2017 11:47 pm
started with the next chassis - it´s for a NASTRUCK
in the meantime - building a rollcage for the Mini Pickup out of styrene tubes. the tape helps to fix the ready parts while glueing the diagonal struts.
Postby BARC 1 » Tue Sep 19, 2017 7:16 pm
Nice work as usual Peter. You build some fine looking cars.( trucks too!!!!).
I should have tired to get something together for the Truck Proxy, but I think I am out of time. I think I have some old Artin Trucks somewhere. Should see If I can get something built from one of those.
Postby taskak » Wed Sep 20, 2017 3:37 am
Nice work with the Minitruck Peter!
I finally finished the Jouef Porsche and added lights to it.
I was planning to just put LED's as a fake lights but then I thought why not to connect power to them
and see how they works.
taskak
Postby pfuetze » Wed Sep 20, 2017 6:04 am
great Porsche, Aki!
nice lights! they always add to the look of a car!
Dan, Artin trucks are fun, but they need a rotating guide! (part of the ProNoMag rules)
i will send an eMail regarding the Kleskun Hills Fun Run shortly.
Postby BARC 1 » Wed Sep 20, 2017 7:05 am
Nice Porsche Aki. One of my favourite cars
Peter,
I would build a chassis and just use the Artin Shell
Postby pfuetze » Fri Sep 22, 2017 12:52 pm
new chassis under artin body shell sounds like the way to go, Dan!
the truck got his body holders today and got a light sanding with the tooth brush and pumice dust.
the Lotus is getting new tires as the old ones are worn down, a fine layer of dust on the Desmo :) thinking about changing the motor from the fyrebox-1 to a milder one ...
Postby taskak » Sun Sep 24, 2017 10:53 am
Cars to the Kleskun Hills are on they way so it's time to start thinking about truck proxy.
Two NASTRUCK resin bodies are coming from Roland, thank you once again,
but there is only 5 weeks before first race so time is getting short.
Luckily I found this and started to work with it immediately.
Started to build two different type of chassis, once finished I decide which one I'll use
Brass version is almost done.
Body is plastic and it's little too small to be exact 1/43 scale, 2 mm too narrow and 4 mm too short.
Trying to get this one done next week before NASTRUCKs arrive.
Aki
taskak
Postby LloydL » Sun Sep 24, 2017 11:11 am
Very nice build Aki!
Regards, Lloyd.
LloydL
Postby BARC 1 » Sun Sep 24, 2017 5:55 pm
Agree with lloyd. Very Nice build on the VW truck. Something I really like about brass.
