by dreinecke » Sat Mar 03, 2018 8:22 pm
Gents, one last topic before I give up for the night: a few cars were penalized by the track with an issue in my blue lane. Several of the cars with really deep guides kept hitting a spot in that lane that would pop them out of the track. No cars had this issue other than those with the big guides. In some cases, the car was coming out almost every lap.
As an example - if you look at radarek's car - he lost 6 laps on the last heat as a result. We discussed trimming the guides on those cars after figuring it out, but I'm not willing to make that kind of a change on them. Sadly, this year is the first time this has popped up.
Some of the gigantic and deep blades I've not seen before and I'm very sorry this happened to the participants. However, as one of the drivers said - things happen in real races too.
Again, the tracks all offset each other in some ways. Each year we see cars go from top to bottom and vice-versa depending on the track. Hopefully this is the case again this year.
Before I run the last leg in October, I'll see if I can somehow file this area out to avoid the problem in the future.
Thanks,
