This car has always sounded like a herd of elephants running down the track. Turns out both axles are bent, the front much worse than the rear.
Is this common?
Has anyone had luck removing the wheels and using a replacement axle?
Doh! That brings up the question of fitting the spur gear (which has quite a bit of wobble in it) on the new axle.
I like the sidewall lettering on the tires. Can the rubber be softened up for use on a wood track?
