Home Racing World • View topic - 57 "Showdown Widow" *Finished*
Re: 57 "Showdown Widow" WIP
Postby HomeRacingWorld » Wed Nov 11, 2015 6:50 pm
We are looking into those Mr. Brew. But those things are costly :)
So time to make and secure the body mounting plate.
First thing I do is sand the inside of the body flush to create a clean mounting area.
I like using this thicker styrene sheet. Some use basswood, balsa, actual posts, etc. I am just happy with this approach. Sit the body down and trace the outsides. Then trim so that the plate just its snugly on the sides. You don't want it to spread the body out too far. Then cut the center out to clear the motor.
I will sit the body right on top of the chassis with the body touching the tires. I mark the tops of the mount tabs.
Fit the plate inside and sit the body back on. You might need to tack the plate with hot glue as a temporary hold to check the clearance. Install the plate where it completely covers the lines you drew. This is normally a great start and you will only need a little adjustment.
You CAN adjust the right side to create a little body tilt/camber. I do this often.
If the ride height is where you want it, secure the plate permanently with adhesive. Super glue works great as ell as good old Testors model glue.
Now adjust the body on the chassis where you want it to be. Lightly tack the body to the chassis with hot glue to hold it in place, then mark and drill your holes.
People have asked about screws. Well, I just order the Carrera screw pack. It has the longer and shorter screws and they do the job just fine. Plus they work in my Carrera models when I lose them :)
This side looks good but I need to lightly sand the back fender well to make it look right. Little too close. It clears, but I'll still sand it.
I like to mount my bodies with a slight offset. Not too much, just enough for effect.
Yes, looks fine.
Test running says we have a decent car. Time to make it look better :)
Postby nhdungeonracer » Wed Nov 11, 2015 11:22 pm
Postby SLOTTING SINCE 1963 » Thu Nov 12, 2015 7:46 am
Also like the colour as is.
SLOTTING SINCE 1963
Postby HomeRacingWorld » Sun Nov 15, 2015 9:16 pm
Ok finished.
The idea I had was that someone found the original Speedy Thompson car abandoned in an old barn. They took it and made a Sportsman out of it. :)
So I tried to make it look for of worn out and well raced.
Pattos decals worked great. Use Duplicolor basic black and white. Wet sanded a lot to let some primer show through in spots, couple dust coats of Duplicolor clear to "rough" it up, wet sand and brushed on 2 coats of Pledge "Future".
Lot of fun with this one. Can't wait to start the next. Thanks all for the comments.
Re: 57 "Showdown Widow" *Finished*
Postby Gameover » Sun Nov 15, 2015 10:19 pm
Looks great boss!!! Love it!!
Postby sweet » Sun Nov 15, 2015 10:47 pm
WOW!...My new wallpaper!
sweet
Postby scatman » Sun Nov 15, 2015 11:14 pm
:music-rockout: Hell yes :music-rockout: Thanks for the step by step instructions.
scatman
Postby CrockettNZ » Mon Nov 16, 2015 12:49 am
beeeeuuuuuutiful :clap:
CrockettNZ
Postby HomeRacingWorld » Mon Nov 16, 2015 9:11 am
Thanks guys. It's a rough looking hammer but it runs :)
Postby nhdungeonracer » Mon Nov 16, 2015 9:25 am
Good job Boss. I think you deserve one of those raises that you're always giving us... :?
Time for you to go to Helen Waite... :lol:
Postby SlotCarCorner » Mon Nov 16, 2015 9:33 am
Great looking car there!
:text-bravo:
SlotCarCorner
Postby DRW21 » Mon Nov 16, 2015 1:02 pm
Very cool car Harry. Looks awesome Mate!!
Looks like its gonna be a real Sow Down for sure!!
What did you use for the air cleaner?
Dave
DRW21
Postby strangebrew » Mon Nov 16, 2015 2:05 pm
It's ALL BEEN SAID.............. :D
strangebrew
Postby HomeRacingWorld » Mon Nov 16, 2015 2:53 pm
Thanks again guys. The air cleaner is a home cast resin. Some guys on here have some like Shotgun Dave, Btaylor, etc. Just holler at them through PM.
Postby btaylor » Mon Nov 16, 2015 2:58 pm
Harry, you have built some nice ones, but the finish on this one really sets it apart from the crowd. I love it!
