Route 66 Rally/Raid layout.
SHOW YOUR SLOT CAR TRACK!
Re: Route 66 Rally/Raid layout.
Postby SpeedyNH » Wed Feb 17, 2016 7:27 pm
I've seen it before. I can't imagine how you remembered or found that.
SpeedyNH
Postby downtowndeco » Wed Feb 17, 2016 9:49 pm
Someone is selling copies of the carpet on ebay.
downtowndeco
Postby HRWJim » Wed Feb 17, 2016 11:17 pm
Is that the carpet from The Shining? LOL that's awesome. Jim
Postby downtowndeco » Wed Feb 17, 2016 11:52 pm
Yes, The Shining. : )
downtowndeco
Postby downtowndeco » Wed Mar 02, 2016 11:27 pm
I put the finishing touches on the IGA. I added the signs, detailed the roof, finished the doors & aged it a bit. Questions?
Image[/URL]
downtowndeco
Postby dreinecke » Wed Mar 02, 2016 11:40 pm
Yeah. When are you coming out to finish my track. I'm about to take a hammer to it!
Postby downtowndeco » Wed Mar 09, 2016 8:47 pm
I finished off the apartment building by adding the remaining walls, the roof, details & then painting & weathering it. I even added an old garden hose for the roof, because not only are roofs often seen more than the sides of the buildings (because we view them from above), real roofs also often seem to be the place where junk collects. The more junk the better. The facade was kitbashed from some O Scale parts. I had to add some height between floors, and of course, make the doors taller. Questions?
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Postby SpeedyNH » Wed Mar 09, 2016 8:53 pm
cool. why is one of the roof vents ugly green with a melted base. was it brass? the other two, look like they belong there, but..
SpeedyNH
Postby downtowndeco » Wed Mar 09, 2016 9:41 pm
Melted base. : ) I just painted it different for variety. Ugly is beautiful IMO. : )
downtowndeco
Postby dreinecke » Wed Mar 09, 2016 10:36 pm
You are simply doing fabulous work as usual. Those buildings look so real. I love that patch work next to the Coke sign and the roof...just perfect!
Postby RV Racing » Thu Mar 10, 2016 8:55 am
This is really a fabulous project in so many ways! I wonder if you would share your weathering technique for buildings -- the materials you use, how you apply and seal them? If you've already covered this subject in a previous thread, just a link or a pointer to where I can find this info would be much appreciated.
Thanks,
Rick V.
RV Racing
Postby slowdogracer » Thu Mar 10, 2016 11:02 pm
What an outstanding job you've done on this
slowdogracer
Postby downtowndeco » Mon Apr 11, 2016 9:12 pm
Next building. This one also features a modified O Scale building facade. I made the side wall using some of my original master patterns, and yes, I hand carved all of the brick for the master one at a time (seriously).
I wanted it to have an old sign that was painted on that would really "place" the layout. You can't get much more obvious than an old Route 66 logo. : )
I found a sign I liked printed it out, and then cut it out like a stencil. I misted the back of the sign with a very light coating of spray adhesive & then pressed in place. I misted it with 3 or 4 light coats of flat white primer & then pulled off the stencil. When I did a little of teh brick paint came off but I thought that looked cool so I pressed some blue painter's tape on the wall (following the brick lines) and pulled up even more.
I still need to add the roof, window glass & some additional signs but here's where I'm at today.
Questions?
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Postby dreinecke » Mon Apr 11, 2016 9:43 pm
1) I figured you were crazy - but carving all of that? WOWEE!!!
2) As usual, you've managed to make my jaw bang off the desk.
Awesome, awesome stuff!!!
Postby downtowndeco » Mon Apr 11, 2016 10:56 pm
Thanks but bricks are my business. : ) Plus once I do a master I make a rubber mold so I can cast as many as I like.
This is what I do for a living; www.downtowndeco.com
downtowndeco
Return to Reader's Roads
