Route 66 Rally/Raid layout.
SHOW YOUR SLOT CAR TRACK!
Re: Route 66 Rally/Raid layout.
Postby downtowndeco » Sat Jun 11, 2016 9:17 pm
Pretty much done. I added more signs and then aged it. I started with a light mist of flat black (grime), followed by some light tan (dust), and finished it off with chalks. I still need to add the bike crashing through the facade, a simple interior & the roof. You get the idea though. Questions?
Image[/URL]
Image[/URL]
The back of the building.
Image[/URL]
Check out the bullet hole. This is laser cut from Dioramas Plus.
Image[/URL]
Biker signs. : )
Image[/URL]
downtowndeco
Postby ourwayband » Sun Jun 12, 2016 5:52 am
That is cool to say the least..
Postby glasshorsevh » Sun Jun 12, 2016 1:16 pm
Randy,
I have been following this thread for a while now and enjoying it very much. This I know is a dumb one, but what are you using to cut the Popsicle sticks? Great work, Thanks!
Val...
glasshorsevh
Postby downtowndeco » Sun Jun 12, 2016 11:04 pm
Thanks, glad you dig it. I cut the sticks w/a utility knife & steel straight edge. I could just score them about half way through & then snap them. I even trimmed some with scissors. The craft sticks were the super cheap dollar store kind.
Cheers!
Randy
downtowndeco
Postby Fast Co. » Tue Jun 14, 2016 2:14 pm
Wow! I haven't been online in about a year and a half and all I can say is Wow! I love it!
Fast Co.
Postby dge467 » Tue Jun 14, 2016 7:49 pm
That came out great, with some cool details!
Postby downtowndeco » Sun Jul 10, 2016 10:21 pm
Tinkered with the scene a bit more. "Planted" the building by adding some groundwork & foliage and then added bikers & bikes. The choppers are Hot Wheels. They say they're 1/64th but they're actually 1/32. The Indian bikes are from another mfgr, I found them on the auction place. The bikers got a raw umber wash & then a mist of Dullcote.This will get a simple interior, lights & sound. A mix of "biker rock" & motorcycle sounds. Still need to detail & weather the roof. Questions?
Image[/URL]
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Postby dreinecke » Mon Jul 11, 2016 9:54 pm
Simply love this track and the attention to detail!
Postby downtowndeco » Fri Aug 12, 2016 9:04 pm
I'm starting to lay down the center highway line. I decided to keep it simple. I used 1/8" yellow vinyl "Track Tape". In help keep the tape centered I made a simple centering tool. It's a piece of styrene, glued to slot guides to the bottom & drilled a small centering hole in the very middle.
Image[/URL]
Stick the tool in the slots, line up the tape exactly over the center of the guide, and press down as you go. The key is to work slowly. I moved the guide about an inch, lined up the tape & rubbed it down, then moved another inch etc. It doesn't take as long as it sounds, I did my whole layout in less than an hour. The other trick is to pull the tape out about 8" or a foot, then wait a few moments to let it relax & shrink back to the correct size. If you stretch it hard & then lay it down right away there will be too much tension in it & it will start to pull up when it shrinks back to normal size.
Image[/URL]
It looks OK now but this is just the first step. Next I need to age it, add some "dashed" passing sections & bring the color down & get it to blend in better. As it stands now it looks like the highway crew just painted it 5 minutes ago! Will get into that next week. Stay tuned!
Image[/URL]
downtowndeco
Postby Z-carfan » Sat Aug 13, 2016 12:01 pm
That is really slick!
Postby downtowndeco » Sun Aug 14, 2016 10:24 pm
I started to age the track & yellow line. Here's the way I did it.
First I used a mixture of black & asphalt colored acrylic craft paint & using an 1/8" wide brush I gave the bright yellow line a thin coat of the paint. Quickly, before it dried, I gave the fresh paint a swipe with my finger & removed about 75% of it. This thin coat really took down the brightness of the yellow & made it blend in better & not look so freshly painted.
Next, using the same brush & paint, I dabbed a few areas of the line to make it seem as if the paint had completely flaked off or had been poorly painted in some spots.
I masked off the rails & slot using 1/2" tape & then misted the track, first with primer gray spray paint, and then with flat tan spray paint. The trick is to keep the can moving & don't over do it.
Finally I painted on some cracks and patching, again, using the acrylic craft paints. It doesn't too much like plastic track anymore IMO. Questions, comments?
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Postby SpeedyNH » Mon Aug 15, 2016 2:52 pm
professional as always, downtown.
(now some weathering on that blue truck! lol)
speedy
SpeedyNH
Postby dreinecke » Mon Aug 15, 2016 10:23 pm
Excellent work as always!!!
Postby TuscoTodd » Tue Aug 16, 2016 5:16 am
That makes for quite the transformation!
Two thumbs up sir!
Postby downtowndeco » Tue Aug 23, 2016 12:05 pm
I finished painting the track. Here are some helicopter shots of what it looks like.
Image[/URL]
Image[/URL]
Image[/URL]
Image[/URL]
downtowndeco
Return to Reader's Roads
