Home Racing World • View topic - Brass Cutting with Chris Walker
Postby HomeRacingWorld » Thu Oct 20, 2016 8:31 pm
Re: Brass Cutting with Chris Walker
Postby chappy » Thu Oct 20, 2016 8:53 pm
Great article written up Chris. All these tips and tricks of the trade are exactly what many of us need. I dont think you have wasted a second of anyones time.
Postby MoparGreg » Thu Oct 20, 2016 9:01 pm
Great article. Thanks for sharing
MoparGreg
Postby dreinecke » Thu Oct 20, 2016 9:48 pm
I learned about three things...the least of which is I suck at this!!!
Great article, hopefully I'll suck less now...doubtful, but I'll try!
Postby bill from nh » Fri Oct 21, 2016 12:35 pm
This is a pretty comprehensive article on cutting brass. It's not a waste of time for anyone at any level to read. I can't emphasize enough to wear safety googles or safety eyeglasses when using abrasive cut-off disks. Sooner or later, you will get a face full of grit, metal particles, & broken disks. For a Sharpie, I like to use red for marking. At my age, it stands out more than black. :)
bill from nh
Postby mattb » Fri Oct 21, 2016 12:49 pm
I use my air powered cut off tool to cut bigger pieces, my Dremel for small stuff and the HF cutter for tubing.
I have a bench grinder with abrasive wheel and wire wheel. I smooth and straighten cut edges with the grinder and get a uniform finish with the wire wheel. My hobby belt sander will also finish brass, but it is a little harder on the sanding belt.
Eye protection of some type is necessary. You will learn the methods of cutting that throw "sawdust" away from you and not toward your eyes.
mattb
Postby Austin » Fri Oct 21, 2016 3:22 pm
Thank you Chris Walker , I need all the help I can get.
Austin
Users browsing this forum: No registered users and 97 guests
