Home Racing World • View topic - Scalextric Ford MKIV Concerns
Re: Scalextric Ford MKIV Concerns
Postby HomeRacingWorld » Thu Nov 02, 2017 6:51 pm
Well I didn't think they performed that well. The PG 22125's work though if you need them.
Postby HRWAdmin » Thu Nov 02, 2017 8:07 pm
Looks a little better with the PG
Posted using Tapatalk Pro
HRWAdmin
Site Admin
Postby Racie35 » Thu Nov 02, 2017 9:45 pm
Reaming the rear bushing holders lower and jb weld the bushings in will cure it..maybe sand the fronts
Harry's right though..shouldn't have to...it's almost like the rear was an afterthought for them...oops
On second thought...that'll knock the motor shaft out of line..just toss the thing in the parts bin.
Racie35
Postby Wobble » Thu Nov 02, 2017 9:58 pm
What I've read about these has dampened my enthusiasm for them but that photo with the PG's improves the looks no end. Maybe if the tyres were just turned around on the hubs it would make it look more appealing but then there is the skinny motor to contend with too. Does someone have the wheel base and width of the rear axle for these?
Wobble
Postby HomeRacingWorld » Thu Nov 02, 2017 10:29 pm
I’ll post more tech data tomorrow if it will help.
Postby Ky.Slot Racer » Fri Nov 03, 2017 4:28 am
Harry,
I hate to see this poor car not get the needed attention, feel free to send it here for some proper love .... :dance:
Ky.Slot Racer
HRW Master Modeler
Postby RichD » Fri Nov 03, 2017 7:01 am
To me that car just does not look right, for a start it looks like it has 14 inch wheels. If it would be any help Sloting Plus makes 0.3 and 0.6mm offset bearings.
Postby BRS Hobbies » Fri Nov 03, 2017 11:06 am
Anyone know of a larger diameter metal rear wheel that will accept the stock tire? Then you can sand down the stock tires some and still have more ground clearance.
Best regards,
Brian
BRS Hobbies
Postby waaytoomuchintothis » Fri Nov 03, 2017 11:11 am
I suspect the only viable solution is what we said at first- its 2 parts, lower the axle and get rid of the rear wheels and tires. You can easily make inserts from the plastic wheels, and swap the motor if its necessary after making the rear drive so much smaller.
Postby WB2 » Fri Nov 03, 2017 11:38 am
Or buy an MRRC or NSR.
The swoop on the rear quarterpanel on the Scalextric just doesn't look right, nor do those weird looking wheel wells (it's almost as if the designers used the photo of a leaning car to make the prototype).
At least they got the front opening rear "hood" right, something NSR missed. That was a Sebring-only item.
And that goofy raised rear spoiler.
Call CG Slots or Olifer and have them whip up a printed chassis.
Rather sad an icon car was so crudely done, especially in light of the recent Ford DP car that was great.
WB2
Postby Cincyslots » Fri Nov 03, 2017 12:21 pm
All that said, I do think it "looks" better in person.
Cincyslots
Postby Modlerbob » Fri Nov 03, 2017 5:55 pm
Looks like a candidate for an Olifer 3D printed chassis.
Postby HomeRacingWorld » Fri Nov 03, 2017 7:17 pm
Postby waaytoomuchintothis » Fri Nov 03, 2017 10:45 pm
I wanted to be the hero that figures this one out, but when I began shopping for one... I bought another Javelin instead. Frankly, I'm not sure I would want the car with all the body errors, Mr. Bubblehead included, even after coming up with something amazing to fix the chassis/rear wheel nonsense. So I ordered the Javelin and did a pre-order for another Javelin that's coming soon. Chances are I will have spent less on these two than buying and fixing the MkIV.
Postby Slot GT » Fri Nov 03, 2017 10:50 pm
I just have to know...is that drivers head actually as big as it appears to be in all the photos I've seen. It looks huge.
Shame about this car. I was looking froward to getting one.
Slot GT
Users browsing this forum: No registered users and 162 guests
