BMW M1 Gr. 5 - hybrid chassis
For 1/32nd Scale Models
Postby VTECFOUR » Sat Oct 20, 2018 7:19 pm
Got a hybrid chassis build going on for a Sideways BMW M1 Gr. 5 body, a visiting gift from Bob at the sadly defunct Victory Lap Hobbies.
Body's mocked but way too low for even me.
Too late as an entry for the upcoming North American Gr. 5 Proxy but I'll have a whole winter to fine tune for the next series.
VTECFOUR
Re: BMW M1 Gr. 5 - hybrid chassis
Postby Lou E » Sun Oct 21, 2018 7:58 am
That is a good looking chassis, nice work!
Lou E
Postby VTECFOUR » Sun Oct 21, 2018 10:04 pm
Added some flexi .032" brass side pans and tuning lead.
Noticeably improved handling and driveability.
Body mounting's next.
VTECFOUR
Postby arroldn » Sun Oct 21, 2018 11:03 pm
Dan,
You still have time. Get it finished and send it in. I still have to start on mine. 10 days until due date.
arroldn
Postby VTECFOUR » Mon Oct 22, 2018 3:19 pm
@ arroldn - I'm sure F1Fan, the organizer, would have to clear this first, but I'm fine being on the sidelines for this upcoming edition. I'd like to learn more about prepping NSR rubber tires anyways.
In the meantime, the body's mounted. Worked out nicely with the sidepans flush with the sills...
...and having a good stance.
My rear track was as narrow as I could get and didn't allow the wheels/tires to be tucked within the body. Then I remembered chrisguyw's trick of modifying the Slot It sidewinder motor pod by replacing the spherical bushings and holders with Parma oilites. That would give me the extra narrowing millimeters.
Worked a treat with the wheels/tires easily tucked in now. Thanks Chris.
Quite pleased with the outcome.
VTECFOUR
Postby VTECFOUR » Mon Oct 22, 2018 11:13 pm
Got some modeling details done. Only got the body, so wheel inserts and a rear spoiler were needed.
Made wheel inserts from Slot Its with the centres replaced with resin cast ones. Think they're actually from a truck but I like the look. Found a NSR Mosler rear wing with a Dunlop marking that'll work.
Paint detailed the rims and wing.
Looks good to me.
Runs really well too so we're good on all fronts.
VTECFOUR
Postby JT Previa » Tue Oct 30, 2018 7:38 pm
Hey Lowrider - Love that chunky M1 body and the paint scheme...the chassis is pretty okay too, I guess...
:banana-dance:
But, what ever did you do to the inner side of those rear tires? Please don’t tell me a Hudy did that!
JT
JT Previa
Postby VTECFOUR » Wed Oct 31, 2018 2:35 pm
Hi JT,
Those were just set up rims/tires.
Replaced the uglies with new PGs for a noticeable performance improvement.
All is good.
VTECFOUR
Postby SuperSlab » Wed Oct 31, 2018 9:48 pm
That looks great Dan! Will you be bringing it to Luf's on Friday? If so I will also bring a Gp 5 proxy build M1 for some comparative running. And is that a Scaleauto red can motor? If so: LOTS of horsepower there!
Alwyn
SuperSlab
Postby VTECFOUR » Thu Nov 01, 2018 12:53 am
Hi Alwyn,
Yes, I`m bringing it to Luf`s. I`d like you to drive it and provide your impressions.
Also, I have questions about NSR rubber tire preparation for you.
See you soon.
VTECFOUR
Postby VTECFOUR » Mon Jun 24, 2019 3:43 pm
Continuing the improvement of previous builds.
Made two changes. Went from a single rear body post to two single ones attached to each chassis side pan.
Placed motor pod urethane washers between the chassis and pod and locked attachment screws with nyloc nuts for minute adjustments.
Side body screws and rear motor mount nylocs were set loose and got some big improvements.
Fastest lap went from 5.814 seconds to 5.614. Two tenths is a big change. The car is quieter too, no doubt the use of urethane washers for body and motor mounts were the reasons.
Nice to see it perform as originally hoped for.
VTECFOUR
Postby Kevan » Mon Jun 24, 2019 5:08 pm
As the Gr5 proxy comes to an end for the last time you may need to find a GT3 body that's fits for the next proxy...
Kevan
Postby Rleog » Tue Jun 25, 2019 4:03 am
Thanks for this well illustrated tuning/build thread, Dan. It’s info like this that, hopefully, helps me become a better tuner. Still much to learn.
Bob G.
Rleog
Return to 1/32 Showcase
