69 Nova sportsman build
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby olddude13 » Tue Mar 19, 2019 7:10 pm
Getting parts together to build a sportsman car
Using #8 from a Lorenzon build
Waiting on a 69 kit and 9 hole rims
Here’s what I have so far
olddude13
Re: 69 Nova sportsman build
Postby olddude13 » Thu Mar 21, 2019 4:57 pm
Body showed up
olddude13
Postby Fathead59 » Thu Mar 21, 2019 7:38 pm
Looks to me like it might be a nice build .
Fathead59
Postby olddude13 » Fri Mar 22, 2019 5:29 am
Fitting body and my son is building a Mclaren f1 gtr
olddude13
Postby olddude13 » Fri Mar 22, 2019 5:33 am
Wheel marking trick, stick axle out stack spare wheel on and trace
olddude13
Postby williamg » Sat Mar 23, 2019 7:09 am
nice
I like the wheel trace trick too
williamg
Postby olddude13 » Tue Mar 26, 2019 7:16 pm
Made some more progress
Paint and decals, temporary inserts and made rear spoiler out of aluminum
olddude13
Postby TuscoTodd » Wed Mar 27, 2019 10:51 am
Dig the tire trick - nice, simple and helps insure that the opening of the wheel well is the same on both sides and centered. :)
Great color scheme and decals - definitely looks the parts!
Postby olddude13 » Sun Mar 31, 2019 5:05 pm
Almost done missing my 9 hole inserts
added 3m foil on bumper corners and use it to temp hold windshield in place while i swab epoxy with q-tip
Thanks to Junior for the driver figure
olddude13
Postby noddaz » Sun Mar 31, 2019 7:56 pm
Heck yeah! Where is my grinder and model kits... lol
BTW... Olddude13, where did you find the big sanding drum?
Scott
noddaz
Postby olddude13 » Sun Mar 31, 2019 8:37 pm
I’m not sure where I got it from i’ve had it a while when it’s loaded it measures slightly over 1 inch Perfect for the tire diameter I think you could actually get it at a Lowe’s or Home Depot If not a good machinist type supply house
olddude13
Postby olddude13 » Tue Apr 02, 2019 5:50 am
Finished !
olddude13
Postby TuscoTodd » Tue Apr 02, 2019 7:42 pm
That turned out AWESOME!
Bravo sir! :D
Postby FC47 » Wed Apr 03, 2019 4:39 am
Yup, really nice look to all of them!
FC47
Postby olddude13 » Wed Apr 03, 2019 5:50 am
Thanks, for the kind words
I have a 67 Chevelle in the works
olddude13
Return to HRW 1/24 Scale
