Almost Finished
HO Scale Slot Car Forum
Re: Almost Finished
Postby arcarace » Fri Sep 20, 2013 10:59 am
I'm a died in the wool 1/32 scale oval racer, we have a club here in southeast wisconsin with a series of tracks that are models in themselves. I think your mods are out of site, any pics of the tracks you run on?
Racerrick
arcarace
Re: Almost Finished
Postby kcl » Sat Sep 21, 2013 7:38 am
Thank you for all for the comments.
Racerrick I have no tracks around here to run on. Use to have one in the basement but
it got torn down many moons ago but I still like to build and fiddle with the cars and
see how far I can go with building them and trying new things.
Kevin
kcl
Re: Almost Finished
Postby hoganracing » Sat Sep 21, 2013 9:56 am
Kevin,
All your builds look great and show a great deal of imagination, ingenuity and skill. Thanks for sharing them with us.
Patrick
hoganracing
Frequent Flyer
Re: Almost Finished
Postby kcl » Sun Nov 03, 2013 7:12 pm
Got a new build working. Started with a Datsun 510 body.
Narrowed it, set the roof back some and shortened the back deck.
So far this is what we have
Kinda looks like a Chevy Nova in some ways. Need to clean up the chassis some and
start on a hood for it next.
All for now
Kevin
kcl
Re: Almost Finished
Postby dreinecke » Mon Nov 04, 2013 7:59 am
Kevin - that looks great sofar. I agree, it looks like the '66/67 Nova if I look at it just right.
Re: Almost Finished
Postby red73mustang » Thu Nov 07, 2013 10:40 am
Those look amazing Kevin! you really captured the essence of North East Modified Dirt Modifieds ("Jalopies" to our mid-western friends :lol: )
Some questions, how do you bend the paper clip roll cages and bumpers so prescisely, are all your exhaust headers brass tube (some look like RRR resins), What body filler do you use to make the hood scoops and lastly what do you use to cut and section the bodies with ?
Chet
red73mustang
Re: Almost Finished
Postby kcl » Thu Nov 07, 2013 6:46 pm
Chet
Chet in answer to your questions
To make the bumpers and cages all I use are these
The pliers are the flat nose kind without any grooves in them. I just bend them by eye and
trim them with a pair of cutters and grind them flat or whatever I need using a dremel
with a cut off wheel on it. No jigs or anything fancy like that.
The only headers that were made of tubing where the ones on the gold coach.
All the others are resin cast made by a guy who goes by the name Partspig.
All the hoods,hood scoops are made from sheet plastic. All the pieces for them
are cut and glued together. Any seams are filled with real thin ca glue and sanded.
Very little putty is used except to fill any defects in the seams after some
primer is applied. Right now I'm using the green squadron putty because I have it
but you can use automotive spot putty also.
Just an example, All these are separate pieces on the hood.
As far as sectioning the bodies, I just see how much I need to take out, run tape on each
side of the cut and make the cuts with an X-acto saw. After cutting I just glue them back
together and hope for the best. the roof cuts and deck cuts if needed are done
freehand by eye. I try sometime to sand the seams before the glue totally dry
and use the dust to fill the seam, again very little putty is used for filler.
Hope this answers your questions
and thanks for asking.
I have no secrets and will share any information
about this I can.
Kevin
kcl
Re: Almost Finished
Postby kcl » Sun Nov 17, 2013 2:18 pm
Got a hood built, not finished but enough to see how it will
look. Found a set of injectors that will work.
Need to sand everything up some more and put some
primer on it to see how it looks.
More later
Kevin
kcl
Re: Almost Finished
Postby kcl » Thu Nov 21, 2013 9:57 am
Body work is done, seams are gone with only
minor filler.
Still needs wet sanded but I'll leave that for
later. On to other things.
All for now
Kevin
kcl
Re: Almost Finished
Postby kcl » Sun Dec 01, 2013 11:29 am
Bumper construction has begun.
This configuration is a second attempt because the first
one failed miserably and looked like it had already been wrecked.
As it's starting to look on the car
Not finished yet still more to add, but looks much better.
All for now
Kevin
kcl
Re: Almost Finished
Postby kcl » Sat Dec 14, 2013 8:45 am
Front and rear bumpers are done
Also added a fuel cell to the back
The cell is attached to the gear plate and fits between the
uprights of the chassis.
More later
Kevin
kcl
Re: Almost Finished
Postby dreinecke » Sat Dec 14, 2013 9:19 am
Kevin - simply fantastic work! And thanks for showing us how you do it! I'll be borrowing a few of those ideas myself!
Re: Almost Finished
Postby TeamMadMarsupial » Sun Dec 15, 2013 10:22 am
As always, looks super neat! Just amazed at the bumpers you build up.
TeamMadMarsupial
Re: Almost Finished
Postby kcl » Mon Dec 23, 2013 6:34 pm
The beginnings of a cage
Start with the u bend so it fits in the body and clears the driver which is the hardest,
the rest is cut and fit, just like the bumpers but takes longer.
More later
Kevin
kcl
Re: Almost Finished
Postby kcl » Wed Dec 25, 2013 9:46 am
Cage is finished and setting up
We'll sand it up later and see what it looks like.
Driver is also ready, paint will come pretty soon.
All for now and have a good Christmas all
Kevin
kcl
Return to HRW HO Scale
