Home Racing World • View topic - NASCAR Build #41 Coors Original...Finished
Re: NASCAR Build #41 Coors Original..Back on da Chassis
Postby SRQSloter » Thu Sep 18, 2014 8:36 am
It's actually the notch that's off. Said the hell with it and put it on. :D Close enough for this one.
SRQSloter
Postby SRQSloter » Thu Sep 18, 2014 8:57 am
Wait till ya see the next one. You may try it instead.
SRQSloter
When ya get your track done. :lol:
SRQSloter
Postby SRQSloter » Thu Oct 02, 2014 3:51 pm
Mount the body and T-n-T time. I was hoping for under 100 grams without any weight. And I can't find another gram to take off the body let alone five. So guess I'll settle for that. Still lighter than the Maverick though.
SRQSloter
Postby SRQSloter » Thu Oct 02, 2014 3:59 pm
Whatever gearing you like.
SRQSloter
Postby SRQSloter » Fri Oct 03, 2014 2:35 pm
Trying something little different for mounts other than tubes. 1/4" styrene angle drilled for SCC body post kit. Just need to put some ca on then hot glue. May be my new way of mounting.
SRQSloter
Postby SRQSloter » Fri Oct 03, 2014 6:53 pm
From the bench to the track. Quick very smooth and stable in the corners. Just a little tail happy coming out of corners but very drivable. Could be the gearing. Little weight tuning will probably fix it. Chassis works great. :dance:
Not bad balance to start with.
SRQSloter
Postby Audi1 » Sat Oct 04, 2014 3:56 am
Postby Florida_Slotter » Sat Oct 04, 2014 5:22 am
Postby SRQSloter » Sat Oct 04, 2014 7:22 am
SRQSloter
Re: NASCAR Build #41 Coors Original...Finished
Postby Audi1 » Sat Oct 04, 2014 2:46 pm
I meant to ask - how does the L angle work to allow you to mount the body? But, I think I have my answer having re-read your post; it joins to the SCC body post kit. Looks like a neat way to do it. I need to read posts more carefully..............
