Home Racing World • View topic - StrangeBrew Vega *FINISHED* (Finally)
Re: StrangeBrew Vega WIP
Postby btaylor » Wed Apr 22, 2015 6:03 am
A lot of us make our own brass motor mounts. It would be very easy to build an AW or SW mount the same way.
Using an old motor can as a drill guide, you can use brass plate or strip, and make a very accurate mount.You could actually make the driveside rear axle holder and motor mount out of one piece if your layout was correct.
Postby Vintage 1/24 » Wed Apr 22, 2015 7:14 am
Vintage 1/24
Mr. NY Modified
Postby HomeRacingWorld » Wed Apr 22, 2015 8:15 am
Thanks.
The rear wheels are the 5 spoke racing wheels CB Design make.
They look pretty good as they are, BUT the nice thing is that they are the same depth/size as a standard insert wheel.
SO if you want a lighter wheel and still want to use scale inserts you can.
But yes, you could easily paint these and they would look pretty snazzy :)
Since I mixed and matched on the fronts, I will use the inserts MT makes on all 4 corners.
Not sure yet...sometimes (ok a lot of times) I am slow on these things. Once I decide on paint/deco, then I decide on the wheel pattern/insert.
Postby btaylor » Wed Apr 22, 2015 8:56 am
Those are some really cool wheels, I looked at the anodized versions too. Some builds would look very nice with a pre colored wheel like that!
Postby RazorJon » Wed Apr 22, 2015 9:10 am
this is looking good
Postby HomeRacingWorld » Wed Apr 22, 2015 2:54 pm
Postby HomeRacingWorld » Thu Apr 23, 2015 9:26 pm
Not much time to tinker, but managed to get the front bumper assembly together.
To create it I simply found a tool that had the size diameter I wanted. My trusty pin vise was the hot ticket. I wrapped the rod around until it overlapped and then trimmed it flush.
Then created the vertical bars and sanded the ends until they dropped in cleanly.
I soldered the assembly on a scrap section of wood. The wood does not act like a heat sink like my steel plate does and it allowed to sit as flush as possible.
The square tubing I use comes in handy to make front mounts that I can adjust. I cut the rods and slid them inside, then adjusted the length.
I think it came out ok.
Still have more work of course.
Postby scatman » Thu Apr 23, 2015 9:33 pm
"I think it came out ok." It's freaking awesome. Sir, I salute you.
scatman
Postby TuscoTodd » Fri Apr 24, 2015 4:03 am
Great progress/how to pics!
Two thumbs up sir! :)
Postby HomeRacingWorld » Sat May 09, 2015 7:01 pm
Been awhile since I had time to work on this old heap...but finished the front supports and rear bumper assembly.
I made a thin brass plate to act as the radiator. It also doubles as the support for the bars.
Not perfect but I'll race it :)
Postby strangebrew » Sun May 10, 2015 9:57 am
Just how I envisioned it.......I'll have to build one myself.
strangebrew
Postby RazorJon » Sun May 10, 2015 11:51 am
Turned out great :text-goodpost:
Postby btaylor » Sun May 10, 2015 12:21 pm
Yep, looking pretty darn good. waiting on the paint scheme!
Postby HomeRacingWorld » Sun May 10, 2015 12:26 pm
"waiting on the paint scheme!" Yes....me too:)
Thanks guys. I hope to do this justice Mr. Brew.
Postby RichD » Mon May 11, 2015 7:29 am
I have never seen a pre-made brass sidewinder or anglewinder bracket. Those configurations would be too wide for the type of car shown here. Years ago Dynamic had cast metal sidewinder brackets.
