by waaytoomuchintothis » Mon Mar 21, 2016 1:09 pm
Bill, I had an "electric solder pencil". They were a sort of cheap, small, low temp version of a soldering iron. I learned about soldering in Shop class in the 8th grade, and we used iron billets on handles, heated in a small gas furnace on the shop bench. After using that kind of heat, that little pencil was disappointing. The binding wire from the newspaper bundles was thinner than coathangers, and the rest of it was brass wire (which is why I had to twist it all the time to get all four wheels on the ground at the same time). Axles were bought as were wheels, guide, braids, and tires. The motor was given to me by a drag racer who wasn't happy with modifications he made to it, and the gears were from a junk Cox magnesium chassis and burned up motor I saw in a trash can. The body was a baby blue '41 Willys by AMT. I was overjoyed to see it go all the way around the track the first time. Everybody in the hobby shop wanted to run it, and I was on cloud 9 all day. Good memories.
