race cooridinater
race cooridinater
Postby Halfj-7 » Sun Feb 16, 2014 4:49 pm
Going to have family n friends over to race the oval. I have both trakmate and race coordinator. We want to set either one for heats/semis/main style with lane rotation during each race, say after a certain amount of laps. Not concerned if the program tracks every seed or advancement to next race, we can do that on paper. Question is, will either program work?
Halfj-7
Re: race cooridinater
Postby HomeRacingWorld » Sun Feb 16, 2014 5:52 pm
Trakmate works pretty good for me. Since you have both then you might try setting up some test races to see which one you like?
Postby slotguy » Mon Feb 17, 2014 9:39 pm
I use a trackmate system for all my races. You can set up a lap or timed heats.if you have 4 racers set it up on a rotion race and than set up the number of laps or time you want to race . If you have more than 4 racers set it up for a round robin rotation race with laps or timed race . Each program will follow each driver througththe complete race and give you a finish order. I use a european rotation so you get to drive next to differant drivers and not the same guy every heat. You can also set up a printer that will print out each heat so the drivers can se how they did in each heat . Also dont forget to set a minamum or brake out time so you dont loes laps on a track call.also set the time that the lap counter stops after the track is turned off on a track call.hope this helps you out.
slotguy
