I don't have access to a meter anymore, but just going on "feel" I set a standard 21 and the new 25BB on a steel plate.
I can feel a slight difference in magnetic downforce. I can't prove it by the numbers, but I am pretty sure it is stronger.
I then took them apart and found the difference
On the left is the original 21 K and on the right, the new 25KBB. It appears the new one is using neodymium style and the original ferrite/ceramic.
Or that is what I am seeing. In any case, the 25KBB does have more downforce. With that armature removed from the can, it still has some (although reduced) downforce when just the can is laid on a metal plate. With the original, there is literally zero downforce until of course you install the armature back in.
