Re: Spirit Porsche 936 Revisited by Bibbster!
Fri Sep 07, 2012 9:30 am
Here is the car that should make a good running mate.
Fri Sep 07, 2012 11:57 am
Well my junk will not come close to yours, except when you pass me.
But I'll try!
Thu Sep 13, 2012 9:32 am
by masmojo
The Black Short Tail 936 is my Favorite car, one of the few that never leaves my box of runners! ;)
Sat Sep 15, 2012 3:39 pm
I started on this car today, and in the spirit (ahem) of this challenge I'll use all the stock parts I can.
However, I noticed the rear axle would not move, unless under a lot of pressure by hand.
I thought it was the gears binding, but after removal it was the axle/bushings. The bushings were so tight I could not turn them by hand.
After removing the wheels, I chucked the axle with bushings in the lathe. The axle is pretty warped. I was going to see if I could wet sand it to get them free, but it's toast.
But the wheels and gear are ok, and I managed to remove the bushings without damage. But I will replace the axle with a section of music wire and report back :)
So, only a axle change for now.
Thu Sep 27, 2012 5:58 am
It went very well. The wheels were easy to get back on the new axle. A session on the tire razor cleaned them up nicely.
New tires and it runs great. In fact, it might be unbeatable :)
