1/ I removed the "fingers" that hold the typical Slot-it spherical bushings.
2/ Carefully reamed the holes to 3/16" (the OD. of my single flanged oilites)
3/ Installed (glued) the oilites with the flanges on the inside of the pod uprights......I have installed lots of bushings with the flanges on the outside,....just depends on how narrow you need to go
This narrowed the rear end by a good 1/4" inch, and I was good to go. Additionally, the glued in oilites are more precise than standard (non glued) spherical bushings.
Below is a pic of standard pod compared to a modified one.
I am also not concerned that the flanges are on the inside (some may think that this could lead to a punched through bushing in the event of a crash), as on all inlines I place my spacers between the gear and the inside of the rear uprights. The spacers center the gear so it does not run on the motor shaft (reducing friction), and, most importantly (on an inline) ensures that my gear mesh is consistent, and bulletproof. It is pain, and may require several widths of spacers, but, it is well worth the effort.......and, I believe critical for the perils of proxy racing. Most folks use spacers between the outside of the pod and the inside of the wheel, and while this is certainly fine, you are counting on the wheels not moving laterally on the axle (this invariably happens.....a shot on the outside of the wheel can move the wheel "in" binding the rear end,.......or,....normal running invariably move the wheels out a tad, which affects your gear mesh.
A couple of shots of "inboard" spacers. It is a pain, and generally needs several different widths, but, you can set (permanently) the gear lash in both directions.
Back to pod narrowing........I recently built a Scaleauto, and wanted to replace the "180" motor with a "130".........this obviously required a completely different gear ratio, and in order to keep the tooth count of both pinion and spur in an acceptable range (not wanting to deviate from .5 pitch to much for obvious mesh reasons), I had to go to a larger dia. spur. This required moving the spur inboard, and here again narrowing the pod by removing the "fingers" was the perfect solution.
This is a pic. of a narrowed Slot-it anglewinder pod.........remove the fingers, ream the holes, install single flange oilites.
Hope this may give one or two of you some ideas on your next build !!
Chris Walker
PS.......A pic. of the "Skinny" Sprite that was the reason for me starting this thread ;)
