Home Racing World • View topic - Noise
Noise
Noise
Postby Perrotoro » Thu Dec 13, 2018 11:06 am
I have cars that run reasonably quiet without the body - then the noise is amplified when the body is attached. This seems more true with Fly, Scalextric, Carrera than with Slot-it and ScaleAuto - the latter two run nearly as quietly with or without body. The Fly/Scaley/Carrera cars have mating surfaces between the body and the chassis, while the Slot-it and ScaleAuto bodies basically envelope the chassis with less body/chassis contact. So is it safe to say that close contact of the body and chassis is a source of amplification of the sound?
Seems likely, as related to a guitar box being tightly bonded. If so, is there already a practiced method to lesson the amplification that results from this?
Thanks
Perrotoro
Re: Noise
Postby chrisguyw » Thu Dec 13, 2018 12:18 pm
chrisguyw
Re: Noise
Postby Perrotoro » Thu Dec 13, 2018 12:52 pm
Awesome Chris. Dang, can't wait to try. May take the afternoon off. :text-thankyouyellow:
Perrotoro
Re: Noise
Postby HomeRacingWorld » Thu Dec 13, 2018 1:16 pm
And that will be #3
Re: Noise
Postby mattb » Thu Dec 13, 2018 2:53 pm
You will find handling is greatly improved if you can mount the body loose enough to rock a little. oversize screw holes, sanding the chassis so it clears the body at all edges. If possible cut the mount posts down and lower the top heavy body. A lot of those 1/32 rtr cars have a high center of gravity and lowering the body can help this a bunch. These tips are a good general rule for every kind of slot car. Noise is still hard thing to eliminate in some cars.
Re: Noise
Postby chappyman66 » Thu Dec 13, 2018 3:40 pm
Some cars just have noisy gear trains. Fly cars are especially known for this but many Ninco cars do it too.
It can be improved by wearing in the gears, but some cars seem like they are just noisy no matter what you do, unless you replace all of the running gear....and that's expensive.
Re: Noise
Postby btaylor » Fri Dec 14, 2018 8:47 am
Sometimes a small patch of Duct tape over the body mount holes will help too. after all the other clearance's are performed. Again, you may need to shave the posts the amount of the tape thickness. I like this method, as I don't lose washers when i take it apart. If the chassis is quiet by itself, it probably doesn't have much gear noise. Its just amplification as you suggest.
Re: Noise
Postby chrisguyw » Fri Dec 14, 2018 9:41 am
chrisguyw
Re: Noise
Postby btaylor » Fri Dec 14, 2018 9:55 am
Oh sure, you could use those. But you would end up with a beautiful and super clean looking chassis like that! :lol:
Good tip, and very nice work on that one!
Re: Noise
Postby Perrotoro » Sat Dec 15, 2018 10:29 pm
Ninco Mclaren: sanded the periphery of body to chassis mate-up. Then used electrical tape at top of posts and got appreciable noise reduction. Will try duct tape for better damping soon.
Since its four posts instead of two, i assume less float is inherant, right?
Perrotoro
