Home Racing World • View topic - 32 Coupe with Ackerman Steering is done. Another one started
Re: Ackerman Steering? Or, are we insane?!?!
Postby dreinecke » Mon Mar 09, 2015 9:00 pm
Yep: Insane.
Very cool though Dave.
Postby HomeRacingWorld » Mon Mar 09, 2015 10:08 pm
Just out of control. And I like that :)
This kind of building is inspiring to me.
Postby SLOTTING SINCE 1963 » Tue Mar 10, 2015 7:52 am
SPEECHLESS! Well done Guys.
Richard
SLOTTING SINCE 1963
Postby ming charlie » Tue Mar 10, 2015 8:08 am
Awesome work guys , I wonder how it would look with a Dago ed front end. In the old days in 1 to 1 the outer edges of the axle was raised up a little to lower the front of the car. I think you might be able to bend the brass just enough. But not having done it I'm only guessing . I want to try this for my jalopy's too . Looks easy in the pictures but I know it's not. Keep us posted please.
Charlie
ming charlie
Postby btaylor » Tue Mar 10, 2015 8:33 am
Charlie, I cant answer for Dave, but a dropped axle set up would be very hard to do. this stuff is so small, that clearances are very tight, and there is not much area in scale to do this. Lazer cut pieces would work for that, but we are trying to design a set -up for the home scratch builder. The other thing being, most old Jalopy's and modifieds didn t use a dropped axle for ground clearance reasons, matter of fact, a lot of them used a straight tube home made front axle, ala Sprint car style. especially when the Original axle assemblies started drying up.
Postby Gameover » Tue Mar 10, 2015 8:44 am
Bob and dave you guys are simply amazing!
Postby RazorJon » Tue Mar 10, 2015 9:21 am
unless your hooking the drive line to the rudder and getting the drivers arms to move im not impressed :laughing-rolling: :laughing-rolling:
good job bud, whats next?
Postby btaylor » Tue Mar 10, 2015 9:34 am
Postby RazorJon » Tue Mar 10, 2015 10:00 am
those huge midgets would be big enough to do the moving arms, double dog dare ya :banana-dance:
Postby RazorJon » Tue Mar 10, 2015 10:13 am
:laughing-rolling:
Postby Gameover » Tue Mar 10, 2015 10:18 am
Lol
Postby btaylor » Tue Mar 10, 2015 10:22 am
The way they say it in the south...."Stand back boys, I got this!"
Postby waaytoomuchintothis » Tue Mar 10, 2015 10:55 am
Who says I'm getting old and forgetful!?! I found it. From 7 years ago!
http://slotcarouthouse.com/viewtopic.ph ... kerman#p63
Postby strangebrew » Tue Mar 10, 2015 11:09 am
Watching with interest........
Don't know if my old eyes work good enough to build something like this.
A hundred years ago I built one with suspension, but I musta' been 13 yrs. old & could see without bright sunlight & mags.
As long as your're this far, you might think about adding some camber (both positive & negative if it's an oval car)
Take a close look at the Nascar boys fronts some time & check the lean on the wheels. They even heat the rear housings to add camber to
the rear & hope the axles don't break.
On the 1:1's when the front steers it raises the positive side of the chassis & loads the opposite rear wheel.
The amount depends on how much camber is built in.
I don't know if that would work with slots without some sort of rear suspension, but maybe if the rear tires
are soft enough & can compress.
:lol: :lol: :lol: :lol: (If you get this working maybe I'll show you how we built 2 speed transmissions in the 60's) :lol: :lol: :lol: :lol:
strangebrew
Postby btaylor » Tue Mar 10, 2015 11:15 am
