Tony, I can answer your question. The draglink or crossbar on the front end has to have a hole in the center. we are soldering a piece of small tubing to the bar on the front side. Your guide must be long enough to drill a small hole into the top of it at the very back. You can use anything as a pin that fits whatever size hole you are able to drill in the rear of the guide. or you can heat up a steel pin, finishing nail etc, and push it into the plastic guide. It must line up with the hole in the draglink.this picture shows the draglink with center tubing soldered on, it is on the wrong side though, unless you have a really long guide, put it on the other side of the draglink.
