REAR SUSPENSION
Too hot to play outside last couple of days, so I thought I'd build something that's been in my head
for a couple months.
I've tried several times in the past 3 or 4 years to build a rear suspension with moderate results.
I'm giving it another try.
Here's the pieces it took to build this version:
The axle is a piece of 1/8 universal speedometer cable, which is an extremely tightly wound
tempered spring; (All you gearheads will know what I'm using here)
I'm using various lengths of 5/32 brass tubing;
& 2 small pieces of foam;
I'm using a piece of 11/32 (I think) brass rectangular tubing on each side of the chassis to mount everything.
..........This is an offset chassis for oval racing...after all this is, Strangebrew......... :D
I've barely inserted a fluted (might help the gear ride against it a little better) 5/32 brass spacer
into the right side rectangular tube & soldered.
Same procedure for the left, except it's a VERY SHORT piece of regular 5/32 brass tube.
This locates the axle in place in the chassis.
All that's left is to assemble the pieces.
I put the 5/32 brass tubes into the rectangular mounts.
These act as bearings for the axle to ride in, but also can rotate in the rectangular tubing.
so you sort of have 2 bushings in one.
I left them extend past the outside just slightly so as the axle moves up & down, it won't bind against
the outside edge of the rectangular tube.
The axle has barley any front to rear movement & is only allowed to move up & down.
The foam was an afterthought to help dampen any chatter from the axle. (My version of a shock absorber)
It runs good on my short oval with no discernible wheel hop. Guess it needs a test run at "headquarters".
The axle is pretty stiff, so I don't even know if it works as suspension or not, but it was an interesting project. :roll:
