Home Racing World • View topic - resin body paint
resin body paint
Custom Paint Job Showcase
resin body paint
Postby rjdadrf@yahoo.com » Mon Oct 07, 2019 8:41 pm
I am having problems with paint on my resin bodies.
the paint never seems to dry.
I clean and dry my bodies with a good cleaner.
I use testors paint on my bodies.
I let the pint dry for about a week before I try to mount any parts
.the paint always seems to be tacky to the touch.
any help would be very nice
thanks
rjdadrf@yahoo.com
Re: resin body paint
Postby munter » Tue Oct 08, 2019 12:35 am
Postby onesixtyfour » Tue Oct 08, 2019 4:52 am
Most resin casters these days use silicone rubber molds to cast parts, myself included.This causes a thin film to remain on the casting afterwards. I recommend soaking the resin parts in a good quality liquid dish soap mixed in warm water for 30 minutes. Then wash the parts under warm running water cleaning them with more liquid dish soap using a small toothbrush. Place the washed parts on a dish towel and let them air dry.
If you still have problems, try washing the resin parts with acetone using a small toothbrush, then wash the parts with liquid dish soap and let them air dry.
Your problem could be that the cleaner you're using on the resin is leaving a thin film of the chemical on the resin, and is reacting with the paint. Even when cleaning with acetone, the parts still have to be washed completely as described above.
onesixtyfour
Postby rjdadrf@yahoo.com » Tue Oct 08, 2019 8:23 am
I use dawn dish soap to clean the bodies with and a brush.
I use testors primer and paint
I will try the acetone on my bodies
thanks again
rjdadrf@yahoo.com
Return to The Paint Booth
