Tractor pulling season is coming!!
Postby nhdungeonracer » Mon May 06, 2013 7:16 am
With spring comes tractor pulling season, and that usually means getting them ready first.
With the great weather we've been having here in the northeast, I've been a tinkering on ours quite a bit. The wife and I (yes, she drives therm too :banana-rock: ) decided it was time for a couple of tractors to have new rear tires...
But you know how it is...what you buy won't be enough. You have to make them better than new. So after 8 hours of cutting and grinding, we're set to go (at least as far as tires are concerned :lol: )
Here's side by side comparison...
Still some work to be done, such as regearing and making more weights, but with the first pull 2 weeks away, this goes a long ways towards being ready... :D
That was my weekend... :lol:
Re: Tractor pulling season is coming!!
Postby HomeRacingWorld » Mon May 06, 2013 7:21 am
Are these part of the new "R" series? :)
Postby ElSecundo » Mon May 06, 2013 7:23 am
You know that you could have just done one, then sent it to Paul Gage to make the others, right? :banana-rock:
ElSecundo
The Great One
Postby waaytoomuchintothis » Mon May 06, 2013 8:39 am
You make your own wheel weights? How? Is there a link to a method?
Postby nhdungeonracer » Mon May 06, 2013 12:44 pm
No, not making wheel weights. But 20-30 lb weights to add to the tractor.
You see, tractor weighs around 500lbs, wife weighs less than 120. Tractor with rider can weigh up to 1000, so I have to add around 380lbs to be competitive.
I've been using steel weights right along, but lead weight is heavier, thus you can have the same weight in a smaller area.
But speaking of wheel weights, I went around to a few garages locally, and have scoffed up all their wheels weights they've taken off when changing tires (it's amazing what a 5 gallon bucket of these weigh!!). I am planning to melt these down and pour into molds of the shape I want. Then I can add these to the tractor...
Postby waaytoomuchintothis » Mon May 06, 2013 1:18 pm
I've wondered if I could make them from ferroconcrete.
