Home Racing World • View topic - Having trouble fitting your new aftermarket tires?
Postby MoparGreg » Fri Oct 11, 2013 3:17 pm
MoparGreg
Re: Having trouble fitting your new aftermarket tires?
Postby FootScoot » Fri Oct 11, 2013 7:28 pm
That's one way of doing it. I wonder what he was spraying on it? Starting fluid? :shock:
Postby Bub » Fri Oct 11, 2013 7:42 pm
Geez, I gotta try that!
"You know you're a redneck if you wake up with both a black eye and a hickey" -J Foxworthy
Bub
Postby HomeRacingWorld » Fri Oct 11, 2013 7:51 pm
Yes, good old Ether.
Sadly I must have done this a 100 times when I was in the service.
Postby dreinecke » Fri Oct 11, 2013 9:18 pm
I saw this in the shop at the AFB in Germany. Works, but I don't want to do it.
Postby nhdungeonracer » Fri Oct 11, 2013 10:57 pm
I've done that more than a few times. And each time it's just really cool when it works!! :lol:
I can say that, cuz I'm still alive to say it. Trust me, while it's cool, it is dangerous as well.
Postby DHansen » Sat Oct 12, 2013 9:33 am
With my luck, I would blow up more then just the tire if I tried that.
DHansen
Postby TuscoTodd » Sun Oct 13, 2013 4:17 pm
I have used that trick a number of times. Works REALLY well when trying to mount 8 or 10 ply truck tires - or if you have a tire that is a bit narrow for the rim that you are trying to put it on.
It doesn't take a lot of ether to make it work and so long as you don't go overboard, it is a quick easy way to get both beads to seat against the rim so you can get the assembly to hold air. You want to be ready with an air line to fill fairly quickly afterwards though, because if you let the heated air inside the tire cool to much without adding anything, you can end up loosing enough pressure that the bead breaks it's seal and you have to start all over again... (been there done that)
Postby 2FER SLOTS » Mon Oct 14, 2013 5:13 am
Got one of these.......works real well.
Hot and tires, not so good.
2FER SLOTS
