Home Racing World • View topic - Solve an old problem...
Postby waaytoomuchintothis » Sun Jan 03, 2016 5:32 pm
Re: Solve an old problem...
Postby TuscoTodd » Sun Jan 03, 2016 6:51 pm
WOW! That sounds like a great upgrade in the making! Looking forward to the updates! :D
Postby HomeRacingWorld » Sun Jan 03, 2016 7:01 pm
I heard the part about a huge oval :)
Postby waaytoomuchintothis » Sun Jan 03, 2016 11:33 pm
I have been stewing about this for years, ever since I replaced the second $150 ballast. The second electrician (the one who actually had some idea of what he was talking about), told me that these lights need a line regulator to keep the electrical feed clean (think about the old days of using car batteries for slot cars and how often we had to clean the braids), or I would keep melting ballasts or whatever was happening to them (god they stink- has to be poisonous, it just has to be). So, I have been in the dim light of four tubes in two fixtures all this time, anytime the weather didn't allow opening all the doors for daylight. And I have been wishing I didn't have to dump all my 1/24-25th cars because the track won't accommodate them. This arrangement will give me a 1/24-25th oval for the big cars and I get to keep the track I have now for the 1/32nds. I can't wait.
Postby Gameover » Sun Jan 03, 2016 11:48 pm
Oval..... Yahoo. Cant wait to see the progress of the build :)
Postby RichD » Mon Jan 04, 2016 8:50 am
If you already have fixtures with regular 4 foot flourescent tubes you can replace those with LED tubes as long as the fixtures have modern electronic ballasts. Different color temperature tubes are available and they even make some that work straight from 117VAC. In that case if you had a fixture with an old fashioned PCB (toxic!) filled ballast you could remove that and run AC straight to the tubes. I paid $13 each for new LED tubes. Another bonus is that if the fixture is in a cold area the LED tubes come to full brightness right away.
Postby waaytoomuchintothis » Sun Feb 07, 2016 7:50 pm
Postby TuscoTodd » Sun Feb 07, 2016 10:08 pm
GREAT looking upgrade! :D
Postby SLOTTING SINCE 1963 » Mon Feb 08, 2016 2:49 am
I heard the part about a couple of ladders !!!!
You no the rule about over 60 and ladders ? STAY OFF !!!
I know we dont listen, be carefull.
Richard.
SLOTTING SINCE 1963
