Building Shelves
Building Shelves
Postby ddyke » Fri Sep 13, 2013 4:52 pm
I am going to build a double row of shelves above my slot track using this type of bracket: http://www.globalindustrial.com/p/stora ... OgodyBMA3g
How far apart should the brackets be?
ddyke
Re: Building Shelves
Postby Jesla » Fri Sep 13, 2013 5:44 pm
How much weight do want the shelf to hold?
We have 24" stud cnt. here so that's what I use.
And I always mount to studs, never trusted those
do-dads that are suppose to hold in drywall or paneling.
Jesla
Postby ddyke » Fri Sep 13, 2013 5:48 pm
18" Studd centers. It will hold slot cars in boxes.
ddyke
Postby RichD » Fri Sep 13, 2013 6:02 pm
My house has studs on 16 inch centers. How far apart the brackets need to be depends on how much weight you expect the shelves to hold and what the shelves are made of. If the shelves will be MDF that material can sag under its own weight and I would put the brackets 16 inches apart. At work we had oak shelves with that type of bracket, the ones that were anchored in sheetrock fell when books were piled on them. If the shelves will be made of something stiffer than MDF and you are only going to put slot cars on them I would expect that having the brackets 32 inches apart would be good enough.
Postby ddyke » Sat Sep 14, 2013 5:37 am
Thanks folks. I will put them on each stud.
ddyke
